20 Most Recent
Genius G-Pen F610 (31100050100) Questions & Answers
Tablet not recognizing pen unless pressing down with it.
Hi, i browsed the Net in three languages to find the solution for this problem but nothing helped, then, accidentally, i bumped into the solution that helped me. I tried everything the same way you did but nothing helped. Since I use the russian version of Windows I do not know how these options might be named in english, but I think you'll understand. In Control Panel there is, as you know, the setup for pen and tablet input (with a picture of a pen) - in it there is a setup for Gestures (the middle one) - in it i disabled the gestures a long time ago. But today i tried turning it ON and went for training of these gestures (the option in blue letters at the very bottom) - and during the training my pen started hovering normally again after half a month of this problem. So I left the gestures enabled after completing the training and it still works fine. Hope it helps you,
Dead zone in my F610
i think its been dropped and this dead zone has damage to the screen or the connections so its a waste of time even trying to get it to work
G-Pen F610 blind spot (pen won't move over particular section)
Sometimes it is caused by a metal plate coming in contact with the sensor pad inside of the tablet. It is only fixable by dismanteling the tablet and putting an A4 sheet of paper between the back side (the one that has the metal plate which can be the culprit) and the green pad (do not touch it!). This issue usually appears after continuous use when the green sensitivity pad is pushed down a little and is short-circuited by the metal pad on the inner side.
I have a Genius G-Pen
There is a conflict in the installed programs on the driver for the tablet and the game software,sometimes due to the video resolution which is common to games that requires a higher resolution that the tablet don't or cannot support.Why not use a handheld control instead which is designed for the games in the first place and for what they are made for.As I use to know that tablets are mainly used for graphics or CAD instrumentations not for gaming and this why your computer is having these issues.
Good day! Whenever I point my pen on the tablet it
hi this sounds like you need to calibrate the pad itself with the software what i mean is the pad has an area which is constricted to that area and what you have to do is literally tell it where the area is, this should be part of the software that comes with the tablet, it sounds like the boundary's are over sized and going over the area that is just required...hope this helps
