20 Most Recent
Utilitech 1/2 HP Convertible Jet Pump 1/2C-JET Questions & Answers
I just purchased a utlitech 1/2 hp convertible jet pump. When I turn it on it just hums.
I
The hum is the sound created by a motor when it cannot start either because the load is excessive and it cannot do the job or if the start capacitor is bogus.
If cap is good, motor should start immediately upon turn on. Measure cap with cap meter or simply replace it. The capacitance should be the amount indicated on the cap and not more than 10 percent less.
If capacitor is good the pump itself might be frozen. Try running the motor not connected to the pump.
How do I tell the pump to shut off when up to pressure?
The black cover on the side is the pressure switch. Open it you will see two screws with springs on them. Don't touch the short one. The tall one will adjust the pressure. Clockwise for more, counterclockwise for less. Cover should have diagram.
New utilitec pump cuts on and off, won't hold pressure
I do not know your system however it sounds like it is on a well system. If so the pressure tank is water bound and needs to be drained. There is a air regulator that needs repair or replacement. I am just taking a guess.
8/18/2014 10:39:13 PM •
Utilitech...
Answered
on Aug 18, 2014
I have a pump #WO313834UTPQP1W
Hi Tata,
There is no match appearing across the web for that identification number of your pump. There may be character missing or swapped. Please verify the support information.
Here is a link offering the pumps at replacement cost which may be more viable looking at the price and effort you may invest in the repairs. Take a look.
utilitech parts for pumps BuyCheapr com .
At the bottom of the page above, a variety of options exist. Below is one of them
Here is a resource further in on the first sight to examine
Top Results for pump parts
Happy wrenching. Fare. Well.
6/25/2014 7:57:59 PM •
Utilitech...
Answered
on Jun 25, 2014
Parts
You can go to: http://pdf.lowes.com/installationguides/819161011011_install.pdf and get the part number from the manual. It is not in English however there are drawings etc. Also stop at your local LOWS store.
6/7/2014 3:56:14 PM •
Utilitech...
Answered
on Jun 07, 2014
Pump does not hold pressure
Sounds line a problem with the water source. A lot of information is needed to answer your question such as model number etc.
6/7/2014 3:44:50 PM •
Utilitech...
Answered
on Jun 07, 2014
