20 Most Recent Apple iPhone (16 GB) Smartphone Questions & Answers
First you need to authorize your PC with your iTunes account with iTunes if you haven't already done so. With your iPhone connected to iTunes and without syncing, at the iTunes menu bar go to File and select Transfer Purchases From - the name of your iPhone.<br>
Besides what mentioned above, I like to share you a article about transferring files from iPhone to computer, which included transferring iPhone photos and videos to computer/iTunes.<br>
Hopefully this works for all of you like it just worked for me!
Apple iPhone (16... | Answered Yesterday
Go to icloud.com and create your ID.
Apple iPhone (16... | Answered on Jul 16, 2019
Hello , I allso forgot my iphone passcode and i unlocked it using www.unlock-iphone.org and the good part is that now i can use my iphone on any network worldwide , i use tmobile in usa now.
Apple iPhone (16... | Answered on Jun 18, 2019
It's a very tricky method. Follow these step precisely, and you should have your own custom ringtone like I have.
Please rate this solution if it helps you.
1 Open iTunes.
2 Find the song that you want to make into a ringtone.
3 Listen to the song and find the part of it you want to use. The chorus may be a good place to start.
4 Write down the start and stop times of the clip.
5 Right-click the song and select "Get Info."
6 Click the "Options" tab.
7 Type in the start time of your ringtone in the text box next to "Start Time" in the minutes:seconds (i.e., x:xx) format.
8 Type in the end time of your ringtone in the text box next to "Stop Time." Make sure the ringtone is no more than 40 seconds long.
9 Click "OK."
10 Right-click your song again and select "Convert Selection to AAC." Wait for iTunes to convert your song. It will create a duplicate version.
11 Right-click the ringtone and select "Delete."
12 Click on the "Keep Files" button.
13 Find the file. It's usually in your User folder under "Music > iTunes > iTunes Music" and under the band's name. It will have an extension of m4a.
14 Replace the m4a extension of your ringtone with m4r. You can either double-click slowly to rename your file, or right-click and select "Get Info" on a Mac or "Rename" on a Windows PC.
15 Click "Use .m4r" or the PC equivalent when the system warns you that the change may affect the use of your file.
16 Double-click the ringtone file. ITunes will automatically add it to your ringtones folder in your iTunes Music Library.
17 Connect your iPhone and sync your ringtones.
Apple iPhone (16... | Answered on Feb 25, 2019
salam,dear, Resolution
  1. Remove any proxy information you have set up.
  2. Update to the latest iTunes software version.
  3. Try turning off your Firewall to see if the issue is resolved (this includes the built-in Firewall or a third-party Firewall such as Norton Personal Firewall, McAfee, Symantec, etc.). Learn how to turn off your Firewall:
Also check me
Apple iPhone (16... | Answered on Jun 21, 2018
For T-Mobile plans are:
$9.99 for Edge internet
$24.99 for 3G internet
Apple iPhone (16... | Answered on Jun 18, 2018
iPhone has an internal rechargeable battery. The iPhone battery isn't user replaceable; it can
only be replaced by an authorized service provider. For more information, go to
www.apple.com/support/iphone/service/battery.
Apple iPhone (16... | Answered on Feb 14, 2018
Alternative option is also available, Kernel recovery for iPod software is a extensive software for retrieving any type of data from iPod/iPhone. For more details: http://www.ipodfilerecovery.com/
Apple iPhone (16... | Answered on Jan 10, 2018
You can retrieve deleted voice mail from your iPhone using an application called iPhone Data Recovery from: http://www.windowspasswordsrecovery.com/iphone-data-recovery/
It's gonna be better to replace your USB cable becuse that's gonna be a bigger problem when the sync fails or worse, when the software update fails. That could turn your iPhone useless.
Apple iPhone (16... | Answered on Oct 22, 2017
If you are using a genuine apple usb lead, replace the charge port in the phone.
Apple iPhone (16... | Answered on Sep 26, 2017
You can enable emoji from the keyboard settings in iOS:
  1. Tap Settings > General > Keyboard
  2. Tap International Keyboards
  3. Tap Add New Keyboard
  4. Locate and tap Emoji
Once emoji is enabled, you can access the emoji keyboard by tapping the globe icon to the right of the space bar:
http://support.apple.com/kb/HT4976
Apple iPhone (16... | Answered on Aug 28, 2017
Your apple phone has a mac address also known as a device id. If you have used the verification method of Whatapp to many times with that phone, this will trigger the verification failed. You will have to email Whats app support for them to resolve this issue. The email is here:
help@support.whatsapp.com
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_50dc26066e33d587
Apple iPhone (16... | Answered on Aug 09, 2017
I had found a guide that fixed many Iphones, and have put every step of their repairs into these guides. These step by step guide will have you using your favourite App. in no time at all.
The iPhone Repair Guides has illustrated photos of an Iphone repair. Follow along and confirm your work with the pictures in the books . Iphone repairs has never been so easy.
Because I have repaired many Iphones using the techniques found in these Repair Guides, this eBook will show guaranteed methods of fixing your Iphone. These methods have been used successfully numerous times by regular people just like you.
Why send your Iphone out to be fixed and pay $150 dollars or more when you can download this eBook right now and have it working again?
Purchase iPhone D.I.Y. Repair Guide Now !
You many just want to change the casing or front face because of scratches , your Iphone falls and the screen cracks, or the wifi stop working . Many different problems are resloved in these guides .
Apple iPhone (16... | Answered on Dec 12, 2016
You can do it either way. Ship it in to Apple and get it replaced for a fee; or if you're more of a tech-savvy handyman you could buy your own screen replacement kit and do it yourself!
http://www.google.com/search?q=iphone+screen+repair+kit&hl=en&tbs=shop:1&aq=f
Apple iPhone (16... | Answered on Oct 19, 2016
If you need help on the part of the iphone, I believe that access to the site will not let you down. http://ydtparts.com/apple
Apple iPhone (16... | Answered on Sep 22, 2016
click the link, in upper right hand corner it will say create new apple id, click on that My Apple ID
Apple iPhone (16... | Answered on Jun 01, 2016
Hi
PUK code is called as PERSONNAL UNBLOCKING KEY.
Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause.
To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code for mobile phone.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider.
While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK code
DONOT enter the PUK code several times wrongly,It will block your sim card permanently.
This PUK code is FREE. You no need to pay any sum to get the PUK code
Thank You.
Apple iPhone (16... | Answered on Nov 02, 2015
Upgrade itunes?
Apple iPhone (16... | Answered on Sep 22, 2014
Apple iPhone (16 GB) Smartphone Logo
Popular Tags
370 questions posted
Popular Products
Top Apple Cell Phones Experts
Ekse
jacobcheatha
Level 1 Expert
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
iPhone Apple
  • iPhone Apple
Most Popular Question
iphone photo recovery
  • Cell Phones
