20 Most Recent
Bushnell Tour V2 Pinseeker Laser Rangefinder Questions & Answers
When I look through the eyepiece the laser is no
If you are seeing the circle through the view finder when pressing top button ( so battery is OK ) but nothing happens when you press the button on top a second time to operate the laser it may be the same problem I experienced .... I noticed a slight rattling from inside my V2 when I shook it .
As it was around 8 years old and a bit battered I striped it down , peel off top and bottom rubber bits then the front rubber cover , this exposes small screws which can be removed easily with the correct screwdriver , once all removed the plastic covers can be separated ...do it carefully and remember which way it all fits back ! It's not that technical but a bit fiddly , I noticed that a small mirror ( prism ) about 1cm long had fallen from its location and was rattling around , I relocated it and added a tiny amount of glue to its edge fixing it in place , I made sure the glass was clean with no fingerprints on it...reassembled and worked fine .... you will need some glue to refix rubber bits , good luck .
Unit will not power on. 2 new batteries did not
The
Bushnell Tour V2 is notorious for suddenly stopping operating.
Normally, if I slap the sides it starts working again. This has happened
many times. I have checked the
batteries and they are great. Try slapping.
If it does not help, Send an Email to below ID to contact Bushnell Email support with issue description and model # :
[email protected]
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
My bushnell wasnpt working great
The Bushnell Tour V2 is notorious for suddenly stopping operating. Normally, if I slap the sides it starts working again. This has happened many times. However, two days ago it quit working again and I have slapped the **** out of it and it still doesn't work. I have checked the batteries and they are great. Try slapping. If someone out there knows something else that will help me, please let me know.
bill
Range finder fell in a cooler
My tablet got wet. I put it away in my room and forgot it for 3-4 weeks. When I found it and tried it - voila! It worked perfectly.
May be thats a solution.
