20 Most Recent
Belkin F5D8631-4 Router (F5D8631au4A) Questions & Answers
Modem router light blinking (no wireless connection) F5D8631-4
Try restoring the Belkin back to the factory default by powering up the Belkin and pressing the RESET button on the back of the Belkin for 7 secs. Then connect a LAN cable from the computer to the Belkin, open IE browser and type the configuration IP address and configure the wireless settings ie. SSID, encryption etc. The computer wireless cards will need to be configured with the Belkin wireless settings to allow them to communicate with the Belkin.
Belkin router F5D8638-4 laptop connects but no internet access
Make sure you entered the same key exactly the same way in both the router and the computer. Also, make sure you have selected a Security protocol that is supported by the computer. Some versions of Windows do not support WPA. XP supports it but really doesn't like to auto detect it. If it's a HP laptop make sure you are using a communications channel other than 6. Some routers give you an option to select the channel HP computers don't like working with channel 6.
Enter client device pin
The client device PIN is a WPS method to connect to the network
I would suggest you disable the WPS feature and go with standard WPA or WEP
To get the PIN :
Turn off / Disable wifi in the laptop
- - Hardwire the computer and router
- - Open the router setup page ( http://192.168.2.1 )
- - Click wi fi Protected setup on the left side
- - Scroll down a little and you can find the router PIN
- - This is the number that you need to enter in the device
To Enable WPA Security in the wireless network
- - Leave the password blank and click submit
- - Disable Wi Fi Protected setup at the top and click Apply Changes
- - Click Security under wireless on the left side
- - Change the security mode to WPA
- - Type a password
- - Save the changes.
Is it possible to turn
Login to the router using a web browser (usually 192.168.2.1 for this particular model.Click on Channel and SSIDEnter your set admin passwordClick on the wireless mode dropdown box and select "off"Click Apply ChangesRouter/Modem may restart - now the wireless is disabled.
Cannot access Http://192.168.2.1 on internet to
Please try the following things:
First make sure that the router's ip is indeed 192.168.2.1.
Go to Start->Run and type cmd and press enter. On the command dialog that opens type ipconfig and press enter. See what the Default Gateway is. That is the address to your router.
The other thing to try is to connect the router with an ethernet calbe directly to your computer. (that is if you are currently using wireless)
Wreless devices causing modem to drop out
You're better off buying a better, new router (one that includes a "Self Healing" feature that will basically reboot the router automatically on a set schedule). Also, try a different brand, Belkin is infamous for making routers that constantly drop connections.
I need to downlaod the
Just reset the modem. There is s small hole in the back that you push the point of a pen in and hold for 10 second. That will reset all the setting including the password.
Is this model compatible with Windows7 and Virgin
This router is compatible with all operating systems. If you try to change the settings in the device, it is recommended that you use Windows Internet Explorer.
Thank you for using FixYa! Have a great day and please remember to rate this solution.
Best regards,
BearWeb
Blue security light flashing!
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Hi
i need a
You do not need drivers for a Belkin router with any win OS.
Perform these steps:
You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
I’m happy to assist further over the phone at
https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Lost password
•Connect the power cord
•Unplug ALL Ethernet connections
•Hold down the reset button for at least 15 seconds
This will reset your router to factory defaults. •Open Internet Explorer (with the computer connected to the Router)•Enter 192.168.1.1 into the Address Bar, push Enter•If 192.168.1.1 does not appear to work, try 192.168.0.1•Under the Username field enter "admin"•Under the password field enter "password"•Click "OK"
Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this FREE answer. Happy holidays!
Tengo un belkin de
SIN PROBLEMAS DE SEGURIDAD
Paso 1: Conecte el Router - PC (con conexi?n de cable)
Paso 2: Abra el programa de instalaci?n del router
escribiendo http://192.168.2.1 en la barra de direcciones del explorador
de Internet
Paso 3: A la
izquierda, haga clic en inal?mbrica Wi - Fi Protected Setup
Paso 4: Deje la contrase?a en blanco y haga clic en
enviar
Paso 5: Haga clic en
Desactivar y aplicar los cambios
Paso
6: A la izquierda, haga clic en Seguridad inal?mbrica
Paso 7: Activar WEP de 64 bits
Paso 8: Escriba un n?mero de 10 d?gitos en la tecla 1
(2 en cada caja)
Paso 9: Haga clic
en aplicar los cambios
Paso 10: a
la izquierda en el canal inal?mbrico y haga clic en SSID
Paso 11: Cambie el canal inal?mbrico a 6
Paso 12: Cambie el SSID a un nombre diferente (sin
espacios)
Paso 13: Haga clic en
aplicar los cambios
Paso 14: Ahora
exploraci?n y conectarse a esta red (inal?mbrica)
Quiero saber si funciona
New lenovo laptop won't recognize belkin router
yes router is working good but your new laptop maybe operating system ned to be configure manually or reinstall wireless security in to your router
advise you to setup your security mode in to 64bit WEP is your new laptop use a windows 7 or vista.
let me know
please rate me techbelkin
I have used this router for a fair while.
Ok My friend lets we talk about your solution.
Before all so many questions coming to my main like
what type of Internet connection do you have :
- IS DSL you need to know if your connection is Dynamic or PPOE. if you don't know just let me know the name of your Internet provider
- if Cable is easy just only need to clone the mac Address of your computer and you will get connected.
Ok my friend let me know if you cant do it and request me a remote your PC.
Note:the model of Belkin do you have is a old model but still usable ok?you lost your connectivity for the activation of security package in to your windows,after you reset your Router all configurations are lose
lets tried please again just let me know .
