20 Most Recent ASUS WL-600g Wireless Router Questions & Answers
You should call on 1-800-585-2494 Toll Free Asus and get your help for Laptop.
ASUS WL-600g... | Answered on Aug 17, 2018
Maybe... Thats the best answer i could give you on it. You would need to login to the router and see if there is the option to filter access by device to the internet, MAC filtering possibly, a lot of routers can do this but i have never seen your model specifically.
ASUS WL-600g... | Answered on Jan 02, 2018
how do I restore user name
ASUS WL-600g... | Answered on Dec 04, 2013
Yes. Just set it up as normal but without the DSL entries. It should still act as switch and WiFi AP.
ASUS WL-600g... | Answered on Feb 12, 2013
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
ASUS WL-600g... | Answered on Sep 08, 2011
Unfortunately you can not completely do what you want with this device because it does not have a ethernet (cat5) port labeled "WAN". The only WAN port is the ADSL phone cable connection. If you connect a ADSL modem or cable modem to one of the LAN ports and your other computers to the other LAN ports you would get public IP addresses for each device up to the allotted IP addresses your internet provider includes with your internet package (usually only two). You will pay for each additional IP address which could be up to $5 extra per month. This would work for internet access to these devices but you will not safely be able to setup file or printer sharing and will not have a hardware layer firewall to ward of hackers and viruses. Your devices, if not properly patched with the latest OS updates and proper firewall, could be compromised within 1 day (NO JOKE). The devices connecting to your wireless would get private IP addresses which will not be able to communicate with the devices plugged into the LAN ports because they have public addresses given by your internet modem and not by the ASUS WL-600g.
In short terms, you can use it like that for wired internet access though very insecure. Devices on the wireless will not have internet access and will not be able to communicate with devices connected to the LAN ports.
Sorry to say its a no go, but its a no go :(
Regards, Chris
ASUS WL-600g... | Answered on Aug 28, 2011
if you have a power adapter to the router this may the issue.
you will possibly need a new power supply or a new router.
ASUS WL-600g... | Answered on Jul 05, 2011
configure the 600G to a static IP on the same subnet as the 722, and then wire it port to port (say, port 1 to port 1, do NOT use the WAN port) - don't forget to disable the NAT/DHCP on the 600G after you assign it's network IP address (not the WAN address, local address, the WAN port will no longer matter and will be unused on the 600G)
ASUS WL-600g... | Answered on May 10, 2011
go back and check your settings for the router--make sure everything is configured for the network. all the lights will be on even if something is connected wrong or not configured. correctly.
ASUS WL-600g... | Answered on May 01, 2010
try reset (press reset buton more than 5 sec, until all leds is off , and power led is red). release button . if power led is allways red, u dont have any firmware on router. and contact dlink to repair (dont say u update the firware, or they charge a new one).
ASUS WL-600g... | Answered on Dec 26, 2009
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
ASUS WL-600g... | Answered on Dec 10, 2009
How to connect to the wireless network?
Problem connecting to the wireless network?
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
ASUS WL-600g... | Answered on Dec 05, 2009
You need to introduce either a firewall or a proxy server in the middle, which could provide this facility.
ASUS WL-600g... | Answered on Sep 14, 2009
Try this website:
http://www.xbitlabs.com/articles/networking/display/asus-wl600g.html
They have a lot of info on this router. On page 6 it talks about the different ways you can access the interface. This may help you get in there.
Thank you,
Mike
ASUS WL-600g... | Answered on May 12, 2009
Sometimes HP printer user face some critical technical issues and unable to fix them. HP Printer Assistant is the better option to troubleshoot the device error.
ASUS Computers &... | Answered on Nov 30, 2019
ASUS WL-600g Wireless Router Logo
35 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
forgot username
  • Computers & Internet
