20 Most Recent
Steinberg Cubase 4 ( Windows / Macintosh ) for PC, Mac (502012300) Questions & Answers
How do I uninstall vst plugins from Cubase 4 ( windows xp )
If you'd like to remove them from your computer you would need to do one of the following 2 things:1. if they were installed from a disc or .exe you can use the add remove program option from the control panel of your pc...once in their look for the name of either the manufacturer or the plugin name and select remove.2. If they were installed from simple dragging and dropping of the .dll or folder files then youll need to go to the main plugin location and physically delete the files. In most cases this location can be found in one or more places depending on your operating system: 1. C-->program files--> steinberg -->vstPlugins or C-->program files-->vstplugins 2. C-->x86-->program files--> steinberg -- vstplugins or C-->x86-->program files-->vstplugins
Cubase 4.0.1 won't run under Windows 7
Try to reinstall the applications responsible for the error:-- It may happen that any program is responsible for the error as one of the main causes is software malfunction. So, reinstall the program by following the below steps:-- Go to Start-> Control Panel->Add/ Remove Programs -> choose the program that needs to be reinstalled from a given list and click on Uninstall button.-- Then after, restart the PC in order to refresh the system setting and make a fresh installation of the program.Replace the Synsoacc.dll existing on the system:In case of file corruption, you need to replace the file with new one as it can help you in the error resolution. To do this, follow the below steps:-- At first, connect online and download a fresh file to save in the computer's memory-- Browse to c:\Windows\System32 to find the existing file on your PC and rename it to synsoaccBACKUP.dll.-- Now go to Start-Run and type cmd to open the command prompt.-- There type the command regsvr32
synsoacc.dll to finally replace the file.
Hi.while installing win 7 ,after
Buy it or read the Terms of Service. We do not help with
"By
using the Site, you agree heartily not to do any of the following:
Publish on this Site any materials, including questions, comments,
suggestions, ideas, plans, notes, drawings, original or creative
materials or other information, provided by you either in the form of
e-mail or submissions to FixYa, or postings to or on the Site
("Content") that is unlawful [...]"
If you did buy it, then the activation code may be on the box or in the manual.
I cannot find my edit
chnge the screen resolution to a lower resolution (start - settings - control pannel - display), the you will find the lost window. (after that you can chnge back the resolution again).
Vista 64 bit audio engine will not start. cubase
If you're using the same software on the 32 bit and the 64 bit, that's probably the problem. You could find the right software for your version of Windows if you searched online or at the manufacturer's website.
