20 Most Recent
Andis Outliner II Hair Trimmer Questions & Answers
Andis Outliner II Trimmers
look if the trimmer is pulling hair, its not lack of oil
its maybe the speed of the trimmer needs to be faster.
its the the plastic flat head skrew on the side.check if the blades separate easiley if theyt do sometimes that makes the trimmer pull hair to.there might be a little plate on the inside of the trimmer and its not holding the blades tight.adjust that not to tight though then the trimmer wont cut
I have an Andis outliner II I purchased a year
Sometimes the new blades from Andis are not sharpen enough to get that clean cut. also all trimmers need to be readjusted for power and alignment, plus sharpening the blade, it look like you need a complete sharpen & service on your Andis trimmer. check out Manny's Sharpening they have a Mail Order service, the service they provide is fast and they will sharpen make all the adjustment and give your trimmer more power and the blade will cut clean. They will even adjust the blade at your request on how you want that blade to be set at. Line Ups or Fade Cuts and even shave set. Manny's Sharpening been around for over 20 years and they have a very good rating on the net.
Check it out
Manny's Sharpening
Andis outliner ii
OHOHOHOHIt is always the same to be careful of el. current in different countries.By my experience I would think that the trimmer will not recover from the exercise.I hope I am wrongKolbrun
I'm in the UK bought my
This trimmer is only made to be used with 110V, we do not have this model in 240V. There is no way to stop the noise. If you would like to purchase a unit made for 240V please call 1-800-558-9441 and speak with one of the Andis customer service reps.
Thank you for purchasing Andis.
My bolt is stripped and my blades are out of place
Guess you have to get the bolt out first and then replace the stripped bolt.
You can do this by using a small drill bit into the middle of the bolt. Be careful with this. After drilling the whole in the middle insert a nail and pull it out.
Be careful with the bolt threads. After removing the bolt, you will have to find a replacement bolt. Try a local hardware store, such as home depot.
THen put it all back, use oil to lubricate and make sure to align the blades.
God Bless You!
I have some green colored
if the shaver is working fine i would not worry about it , they use electrical grease and they also use grease on some of the internal working parts . it might be that the shaver got to hot and melted some of the grease . i would just wipe it off .
