20 Most Recent
Panasonic TC-P42X3 VIERA 42 Class 41.6 Diagonal X3 Series Plasma, Aspect Ratio 16:9, Native Resolution Number of Pixels 786432 1024 x 768, Moving Picture Resolution 720 lines or more, Shades of Gradation 6144 equivalent, 24p Playback 2:3, Deep Color, x.v.Color Questions & Answers
How to reset lamp for Panasonic PT-vx400nt?
Turn off and unplug the projector.
Locate the lamp cover on the projector.
Remove the lamp cover.
Take out the old lamp.
Insert the new lamp.
Replace the lamp cover.
Reset the lamp hours:
Press the Enter button to display the "Option" menu.
Use the 5 or 6 button to select "Lamp Runtime".
Press and hold the Enter button for approximately 3 seconds.
The "Lamp Runtime" will change to "Time Reset [Power Off]".
Turn off the power and disconnect the power cord.
Finally, plug in and turn on the projector.
Remember to consult your projector's operating instructions manual for specific details and safety precautions.
How to change Panasonic vx 400 xga projector lamp change or replace (youtube.com)
2/17/2024 12:59:14 AM •
Panasonic...
Answered
on Feb 17, 2024
On the Panasonic DMR-EZ47V, it had a VCR tape stuck in it, when turn on shows, F60, now doesn't show anything.
Yes bad caps on the video processing board according to the links
iFixit
https://www.ifixit.com > Answers > View > F60+error...
Oct 8, 2014 - Ron, F60 is a general error code usually related to a
failure on the video processing board. You could fix this by just replacing that board ...
I have a DMR EZ485 that shows an error code of F60. What
JustAnswer
https://www.justanswer.com > Electronics Question
Jan 5, 2018 - The
F60 error is an error that indicates a video processing board failure. Here are a few things that you can try (do one first then try number ...
1 answer · Top answer: Hi, I'm JA Engineer. Welcome to JustAnswer. I'm reviewing your question now and will post back ...
Panasonic DMR-ES40V Drive and F60 Code
AVS Forum
https://www.avsforum.com > threads > panasonic-dmr...
Oct 26, 2014 -
F60 is a result of a low or missing voltage on the digital board. Often the culprit would be capacitors that have leaked. But first try a "cold ...
Another Capacitor Failure, Another Fix
EE Times
https://www.eetimes.com > another-capacitor-failure-a...
Jan 21, 2019 - An online search revealed that
F60 was a general failure code, usually caused by a failed aluminum electrolytic capacitor. Time to get the ...
Picked up a Panasonic DMR-EZ475V that throws a code ...
Reddit · r/VHS
2 comments · 2 years ago
The VCR and DVD recorder won't eject/open on command either, so my guess is the capacitors on the power board are dead. Upvote
My Panasonic DMR-ES40V DVD/VHS player now says " ...
JustAnswer
https://www.justanswer.com > recorders-and-players
Dec 23, 2012 -
F60 is a general error code indicating a failure on the video processing board. First try a "cold boot". Unplug the recorder again, allow it to ...
1/30/2024 3:40:50 AM •
Panasonic...
Answered
on Jan 30, 2024
Need to access menu on Panasonic viera without remote
If you need to access your Panasonic television's menu and you don't have a remote, then your best option is to use the physical buttons on the television itself. There is a MENU button, often on the back of your Television.
12/11/2023 9:37:19 AM •
Panasonic...
Answered
on Dec 11, 2023
