20 Most Recent
Wahl Magic Clip Clippers Hair Trimmer Questions & Answers
My wahl clipper is very noisy, what should i do to
First, they need to have a drop of oil put on the cutters every time they are used. Second, there is usually an adjustment screw on the side of them to adjust the travel of the moving cutter. Adjust that so that it completely goes across the slots in the stationary one, but not too far or too noisy.
Philishave C482. I cannot see
Very easy. Remove the adjustable comb; then pull on the teeth of the cutter and it will come off the machine. Take a small flat screwdriver and insert it in the slot of the tin clip inside the chamber that was revealed when the cutter popped off. Lever the tin clip up and away and then remove it completely. Now we have the body of the shaver ready to take apart. The outer shell consists of two halves that are simply snapped together. Take a wider flat screwdriver, insert it between the two body parts on one side and twist until you get a little snap. Slide the screwdriver about halfway down the body and repeat the twist action. Then do the same on the other side. Then force the body to come apart in the back by the same technique and you're in!
My newly bought WAHL hair
The only thing here you can do is, if you want your blades to be sharper you need to send them to a professional sharpening service. Manny's Sharpening can help you with that, We have a mail order service with includes Free return shipping. We only charge $8.00 per blade set.Check out my web page, we also included a shipping Label and order form.
Manny's Mail Order Sharpening
