20 Most Recent 1994 Toyota Camry Questions & Answers
1994 Toyota Camry LE 2.2L. Is there a list of every single part that goes into it?
Question edited for clarity. Question moved to model category. Yes there is. AutoZone and Rock Auto list all the parts that are likely to need replacing. This says it has them all, I caught a glimpse before the site noticed I have an Ad-Blocker :>D
camry parts list.pdf (18.9 MB) - Data sheets and catalogues
toyota-club.eu https://en.toyota-club.eu > manual_download Toyota Camry XV10 Data sheets and catalogues English 18.9 MB. https://www.google.com/search?q=1994+toyota+camry+le+2.2+parts+list+pdf ..
8/26/2023 11:01:26 PM • 1994 Toyota... • Answered on Aug 26, 2023
I have a 1994 Toyota Camry that the hazard nor the indicator lights doesn't work. It doesn't display on the dash
Hello . first check the fuses , then find the flasher its self .Usually in the fuse panel down by where your feet go or in the glove box . Check the manual to see where its located . Its usually about an inch square or an inch round and just pulls out to replace it .
12/15/2021 10:42:22 PM • 1994 Toyota... • Answered on Dec 15, 2021
3answers
Locate fuse box toyota lite ace van 1994
most 94 van fuse boxes are located behind center console I could not find ace van on alldata
9/11/2021 7:49:51 PM • 1994 Toyota... • Answered on Sep 11, 2021
2answers
1994 Toyota Camry, need wiring diagram for fuel pump and hopefully circuit description and operation. 4cyl 2200 on what controlls pump.
You can try the autozone website, make a free account and put in the vehicle information then look for the free repair guides. It has electrical info. If they dont have it there is a site called ALLDATA and they will have it but it is not free.
8/29/2021 7:18:18 PM • 1994 Toyota... • Answered on Aug 29, 2021
How do you change spark plugs on a 1994 Toyota Camry V6?
This guy figured out how to replace the back plugs without removing anything. Genuis!
7/15/2021 10:51:10 PM • 1994 Toyota... • Answered on Jul 15, 2021
Where do I locate the spark plugs on a 1994 toyota
On a 4-cyl they are on top of the engine in the midline of the cam cover. On the V6 they are at the front and back of the engine as you look at it, 3 each bank. The back 3 on a V6 are especially difficult to get at, and I'd recommend removing the intake plenum to get at them. More details here for each enginehttp://www.turboninjas.com/camry/eg1.pdfhttp://www.turboninjas.com/camry/eg2.pdf
7/15/2021 10:48:54 PM • 1994 Toyota... • Answered on Jul 15, 2021
2answers
I have a 1994 toyota camry and while driving the engine dies off,then after i stop a few minutes later it starts then i can drive off again
It does sound like fuel pressure is low or intermittent. Here are some check procedures p172 onhttp://www.turboninjas.com/camry/eg1.pdfIs the check engine light showing a trouble code on the instrument panel? That may pin the trouble down.
4/27/2021 6:21:52 AM • 1994 Toyota... • Answered on Apr 27, 2021
3answers
I need help I don't know what color wires go to
I have a radio wire connector on a 1994 Toyota Camary and the color don' match your list, here is my list.
2 reds, one silver dot, one double silver dot.
2 blacks, same as above,
2 greens, same as above.
2 whites, same as above.
2 browns, same as above,
1 white w/green stripe, two silver dots
1 black w/red stripe, one silver dot.
1 yellow, two silver dots.
1 blue, two silver dots.
the numbers on the connector are A02 16 14 11264 9 8.
I'm clueless which wire are which.
5/25/2020 3:08:36 PM • 1994 Toyota... • Answered on May 25, 2020
What is the firing order for a 94 toyota camery le
Here's a link to your firing order. Specifications Firing Order AutoZone com
4/3/2020 11:30:37 AM • 1994 Toyota... • Answered on Apr 03, 2020
4answers
Fuse box diagram 94 Toyota Camry V6 Coupe
Cigarette/radio is a 15amp fuse located in the panel, middle row, bottom fuse. Basically you have 3 colums and 4 rows of fuses in there.
1/10/2020 7:15:28 PM • 1994 Toyota... • Answered on Jan 10, 2020
1994 Camry LE 4cyl where is the actual location for the EFI relay circuit fuse
It is a 15amp fuse probably the only one in the bank as they changed positions of the fuses for different models but try the bottom left corner if the fuse box
10/3/2019 3:12:35 AM • 1994 Toyota... • Answered on Oct 03, 2019
94 toyota camry 3.0 fuel line schemat
come from gas tank
7/25/2019 3:40:33 PM • 1994 Toyota... • Answered on Jul 25, 2019
1994 toyota camry timing marks
How to set thetiming on a camery3000 V 6 the rear top campshaft
5/25/2019 8:21:39 AM • 1994 Toyota... • Answered on May 25, 2019
Location of fuel pump relay on 94 toyota camry
Remove Glove Box for access - relay is located behind the glove box - Fuel Pump relay is the middle one on bank of three. "https://www.6ya.com/callphilipforhelp
2/8/2019 11:30:11 PM • 1994 Toyota... • Answered on Feb 08, 2019
What is radiator volume inc eng in 94 v6 camry ?
doesn't really matter just use a bucket and mix 1/2 and 1/2 in the bucket then pour that into the radiator. It is supposed to be mixed first anyway.
9/30/2018 1:31:47 AM • 1994 Toyota... • Answered on Sep 30, 2018
I have an antifreeze smell coming from the engine.
Check your heater core inside your vehicle, now days their made so cheaply that they don't last long. I had the same problem that you're dealing with, no leaks to be found and discovered that my heater core was leaking inside the cab just enough to smell and I went thru 3 new ones in a week and a half.
2/20/2018 7:37:29 PM • 1994 Toyota... • Answered on Feb 20, 2018
94 Camry starts but idle
Consider a possible fault in the ECU, the computer. It can't be repaired internally, and really the only way to be sure is to trial a replacement. It has to be from the same model, trans and engine. If you can find a wrecker who will allow you to try one out, the swap is easy enough, behind the glove compartment. See here p 234 http://www.turboninjas.com/camry/eg1.pdf
1/25/2018 6:44:33 AM • 1994 Toyota... • Answered on Jan 25, 2018
Adjusting a power window regulator.
The motor needs replacing not adjusting. If you can help the window do up and it stops at the top, it's 'adjusted' properly. You could pull the door panel and maybe lube the motor/drive and cables. It might work a year or a day. But while you have the door panel off why not just put in a whole new unit. It's just as much trouble to 'fix' it as it is to replace it. You could limp thru by spraying some silicone in the window track.
1/6/2018 2:21:09 PM • 1994 Toyota... • Answered on Jan 06, 2018
1994 Toyota Camry Logo
2,444 questions posted
Popular Products
1995 Toyota Camry
1995 Toyota Camry
1,828 Questions
1998 Toyota Camry
1998 Toyota Camry
1,565 Questions
2002 Toyota Camry
2002 Toyota Camry
1,303 Questions
1996 Toyota Camry
1996 Toyota Camry
1,134 Questions
1997 Toyota Camry
1997 Toyota Camry
1,141 Questions
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
View Most Popular
Camry Toyota
  • Camry Toyota
Most Popular Question
air conditioner compressor seems
  • Cars & Trucks
