Open the hood. You will notice there is a large black box on the right-hand side directly behind the
battery. This black box is the fuse box. Pull the top of the fuse box off. There are two clips on either side; once you pop one side, the other comes off very easily. In the top left-hand side of the fuse box where all the fuses sit, you will see a large orange/red block. Below this block is a button that says "reset." Press this button for 5 seconds.
Turn the car on and wait for a minute. If the light does not go on, turn off the car and set the key to ACC on the key
ring. Push the reset button again, holding it for a total of 15 seconds. Turn the key to off, take out the key, return the key and start the car again. Allow the car to run for 2 full minutes. It is taking the system a few minutes to register that this button has been pressed.
