20 Most Recent 1999 Dodge Ram Questions & Answers
1999 Dodge Ram Laramie 1500. Nick diagram for nineteen ninety nine ram fifteen hundred larami
Question edited for clarity. That is a strange way to state 'year make model'!! Question moved from Computers Category Not sure what you mean by a 'Nick Diagram', but as you mention 'speakers; and ' 'take (fake?) twitters' (Tweeters?) I presume you want the stereo wiring diagram?
1999 Dodge Ram Pickup Car Stereo Wire Colors and Locations
the12volt.com https://www.the12volt.com > installbay > stereodetail 1999 Dodge Ram Pickup Stereo Wiring ; Right Front (-), Dark Blue/Red ; Rear Speakers, 5 1/4" Side Panels ; Left Rear (+), Brown/Yellow ; Left Rear (-), Brown/Light ...
1999 Dodge Ram 1500 Radio Wire Guide
modifiedlife https://www.modifiedlife.com > 1999-dodge-ram-150... Our 1999 Dodge Ram 1500 radio wiring guide shows you how to connect car radio wires and helps you when your car radio wires not working. It also shows you the ... ..
10/12/2023 4:37:34 PM • 1999 Dodge Ram • Answered on Oct 12, 2023
1999 Doge Ram 5.9. How to reset to CPU on it please.
'CPU' are the Central Processing Unit is a Desktop or Laptop Computer. In a vehicle they are called the ECM (engine control module) or ECU (engine control unit). The proper way is to use a scan tool. The important question is WHY you want to Reset it? The ECM has been learning stuff since the last time battery power was cut. You can just disconnect the negative battery lead for 20 minutes... but .... https://www.fixya.com/cars/r29912554-changing_battery_not_create_problems To clear codes and historical codes, Drive Clean / Smog Data, you use a scan tool.
7/14/2023 12:16:58 AM • 1999 Dodge Ram • Answered on Jul 14, 2023
3answers
My ram 1500 2w drive
Is there any check engine light on ? It sounds like your transmission is slipping ! Pre 2004 dodge trucks mainly had the the 46re trans wich requires service every 30k wich includes adjustimg the primary and secondary bands ! With my experience this never gets done and leads to transmission problems ! At this point the damage is done so you can try some things - first flush the transmission and drop the pan and have the bands adjusted and put in a new filter , refill with atf plus 4 fluid only and substitute 1 qaurt of fluid with lucas trans treatment and add greased lighting additive and drive for several days ! I did this on a dodge truck i bought that was having problems and it fixed the majority of the problems a computer update fixed the remainder of the problems and she has been running perfect since !
11/27/2022 3:11:04 PM • 1999 Dodge Ram • Answered on Nov 27, 2022
1999 Dodge Ram 1500, 5.2. What could cause my 99 Ram 1500 5.2L engine to lose oil pressure?
Did you get all the "shaving cream" flushed from the engine? It could be plugging the oil pump pick-up screen. The pump could alco be going out. Have you replaced the oil filter? If there is still milky residue you may need to replace it several times.
10/18/2022 2:10:57 AM • 1999 Dodge Ram • Answered on Oct 18, 2022
I have 1999 dodge ram 1500 5.2L. idles good a little low but good but when accelerating motor bogs down and tries to stall. is that my M.A.P. sencor?
I have 1999 Dodge 1500 gas motor. It has a high idle and when I let off the gas it stalls out. The truck also has a engine light on. What do I do??????
9/1/2022 9:11:44 PM • 1999 Dodge Ram • Answered on Sep 01, 2022
2answers
Where will i find the ground wire on my 1999 dodge ram 2wd? My truck will not start just wh.ines over
ground straps usually attatch to firewall, and frame to the block, most veh have atleast 2 start by looking at frame and firewall for broken ******** either. however you can add one by simply finding a bolt on either frame or firewall, and attatch to and from bolt on block make sure the bolts don't hv plastic or rubber though so it will make good contact. (however if it's just whining, that sounds like the bendix is bad in the starter) have you tried replacing the starter?
8/21/2022 1:10:49 PM • 1999 Dodge Ram • Answered on Aug 21, 2022
2answers
1999 Dodge Ram 1500 5.9 Overdrive Not Working
CHECK FOR POWER TO TCC. WHEN ENGAGED .IF YOU HAVE NO POWER THE OD SWITCH IS MOST LIKELY BAD
2/25/2022 10:17:47 PM • 1999 Dodge Ram • Answered on Feb 25, 2022
1999 Dodge Ram 1500. Flasher Relay Constantly Clicking.
Question edited for clarity. Question moved to Dodge Ram. Known issue https://www.google.com/search?q=1999+Dodge+Ram+1500.+Flasher+Relay+Constantly+Clicking ..
12/29/2021 9:52:16 PM • 1999 Dodge Ram • Answered on Dec 29, 2021
2answers
Where is the blower motor located in a 1999 dodge
It is behind the passenger side of the dash. when you look under the dash you will see it. you may have to remove a kick panel
11/13/2021 5:01:52 AM • 1999 Dodge Ram • Answered on Nov 13, 2021
5.9l. How can I join upstream wires to O2 sensor?
https://www.justanswer.com/dodge/19w1p-dodge-wires-oxygen-sensor-signal.html
4/24/2021 2:18:00 PM • 1999 Dodge Ram • Answered on Apr 24, 2021
2answers
WHERE IS MY LIFT PUMP LOCATED ON A 1999 DODGE 3500
if you are talking about air ride system for the most part its under the hood on the driver side or the passenager side close to the fender give these websites a try www.alldatadiy.com and www.autozone.com if all fails stop by your local library and get your hands on a Haynes auto repair manual for your truck wish you the best of luck Michigan Man.
1/24/2021 3:51:17 AM • 1999 Dodge Ram • Answered on Jan 24, 2021
I have a 1999 dodge ram 5.9 and getting no power to injector wires plus no spark where can I start
Did you disconnect the battery recently, or had it standing a long time with a flat battery? Did you check for codes?
1/18/2021 11:59:29 PM • 1999 Dodge Ram • Answered on Jan 18, 2021
TURN SIGNAL FLASHER LOCATION FOR 1999 RAM 2500 HOW
Hello Patty - Check the back side of the interior fuse box, should be between the steering column and the fuse box. You should be able to hear it "click" when in use. Most 2500 Rams had a flasher unit that was trailer ready. You may not need this upgrade. I hope this helps.
12/26/2020 9:30:27 PM • 1999 Dodge Ram • Answered on Dec 26, 2020
Torque specs axle nut 2006 dodge ram 1500 4x4
Torque till 175 ft/lbs, then tighten it further until the cotter pin can be seamlessly inserted.
6/28/2020 11:26:09 AM • 1999 Dodge Ram • Answered on Jun 28, 2020
I have a 99 dodge ram and I recently changed the transmission and its acting like something is loose from shifting I notice this threaded hole missing a bolt or something can that be a issue?
I cannot see how one bolt missing from the transmission would make a difference in shifting.Did you check the fluid? After the car has been driven your fluid level should be at the FULL mark.Not above it, or below it. Also,if your replacement trans came from a bone yard, That could be the problem".Most junk yards offer a warranty for a few dollars."
11/10/2019 6:01:53 PM • 1999 Dodge Ram • Answered on Nov 10, 2019
3answers
1999 Dodge Ram 360 5.8 liter engine feels like transmission is sl
Hi, the problem you are having sounds like the differential needs replacing this can be expensive and hard work but not doing this can cause further damage to your vehicle so its better get it done sooner rather than later.
If on the other hand your only getting a vibration through the steering wheel then this could be that the wheels need balancing.
You should know which of the two problems you have if you need further assistance then just let me know ok
6/2/2019 11:51:14 PM • 1999 Dodge Ram • Answered on Jun 02, 2019
2answers
My 99 dodge ram 1500 v8 magnum just dies while
could be the ignition switch. It's definitely an electrical problem, and the ignition switch is the most likely cause.
2/13/2019 2:03:23 PM • 1999 Dodge Ram • Answered on Feb 13, 2019
7answers
No dome light or radio
It's the IOD fuse. Trust me, I just fixed the exact problem on my '98 not ten minutes ago. The fuse is located in the fuse box inside the driver's side door. It will be the fuse on the bottom and toward the front of the panel with a black cover over it. Just pull the fuse holder straight out and snap the hinged cover forward to expose the fuse. Just a standard 10 amp automotive fuse and you're back in business!
Wes
5/23/2018 11:32:58 PM • 1999 Dodge Ram • Answered on May 23, 2018
1999 Dodge Ram Logo
2,544 questions posted
Popular Products
1994 Dodge Ram
1994 Dodge Ram
197 Questions
2004 Dodge Ram
2004 Dodge Ram
173 Questions
1998 Dodge Ram
1998 Dodge Ram
143 Questions
1990 Dodge Ram
1990 Dodge Ram
114 Questions
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
View Most Popular
Ram Dodge
  • Ram Dodge
Most Popular Question
1999 dodge ram 5 9 getting no power
  • Cars & Trucks
