20 Most Recent 2001 Ford Focus Questions & Answers
WHERE IS THE FREEZE PLUG, ON A 2001 FORD FOCUS
freeze plugs are in the engine block and there are probably 2 or 3 on each side about midway down in a row front to back. They will be round and recessed into a hole that is cast into the block. There is also freeze plugs on the back of the block where the transmission bolts to the engine.
3/25/2024 6:48:40 PM • 2001 Ford Focus • Answered on Mar 25, 2024
10answers
Code for a Ford Mondeo 6000cd radio
Hi Geof
Your radio code number should read: 5796.
I trust this will do the job.
I have no other code for your model.
Please let me know if this works.
Bye Ray
2/18/2023 3:14:41 PM • 2001 Ford Focus • Answered on Feb 18, 2023
2answers
2001 Ford Focus. It is running rough and power surges.
Clean Throttle Body (both sides, not just what you can see) and MAF (mass air flow sensor) [spray and shake to dry]. https://www.google.com/search?q=2001+Ford+Focus.+running+rough+and+power+surges .
2/1/2023 2:33:51 AM • 2001 Ford Focus • Answered on Feb 01, 2023
2001 Ford Focus 30A ingition fuse (#8) blown replaced...ignition wored for couple of weeks. Fuse blew again. Replaced it. It immediately blew again indicating a short...somewhere. Any ideas where to s
Yup I pulled up to my parents house and shut off my 2001 Ford Focus. I was inside maybe 10-15 minutes. But instantly popped the #8 30amp maxi fuse when I went to restart it ??. Thank you for all of the specs/info it's def going to help the search for the short
9/21/2022 6:04:42 PM • 2001 Ford Focus • Answered on Sep 21, 2022
O2 sensor replaced but still stalling out.
Here may be the reason for this problem. The O2 sensor reports a problem with the exhaust gases coming out of the engine. The O2 sensor then sends its signal to the main processor to adjust the fuel mix to correct the problem. There can be a build-up of soot in the system, the catalytic can be bad, or the injectors can be unresponsive and continue to foul the system. You could have bad oil rings which will foul the exhaust. Clear all trouble codes. You can try to use some additives for the fuel system that clean injectors and there are some additives that claim to clean the catalytic converters. I am not familiar with the wiring leads to your O2 sensor. Sometimes a wire will cook or fray and give false trouble codes for the O2 and really the O2 is fine but the wiring is not. As for not showing a problem at idle or neutral there are some manufacturers that design their system to improve idle by having different functions under a load for their O2 systems.
9/21/2022 7:09:05 AM • 2001 Ford Focus • Answered on Sep 21, 2022
2answers
On a 2001 Ford Focus SE five speed where is the automatic door lock relay located
Sorry Andrew , no BCM on this vehicle . The Central Security Module is incharge of power door locks . Central Security Module For additional information, refer to Section 419-10 . The central security module is equipped with a battery back-up which holds the programmed transmitter(s) memory in the event of the vehicle battery disconnection. Principles of Operations The Door Switch Lock Function When a door lock switch is moved into the lock position or a door lock cylinder is rotated to the lock position, the door lock switch grounds the lock circuit input to the central security module. The central security module then provides 12 volts to one side of the door lock actuators contained in the door latch unit and simultaneously grounds the other side of the door lock actuators. This completes the door lock actuator circuit, causing the door lock actuators to rotate a cam assembly, which then locks the doors. The Door Switch Unlock Function When a door lock switch is moved into the unlock position, the door lock switch grounds the unlock circuit input to the central security module. The central security module then provides 12 volts to the opposite side (relative to locking the door) of the door lock actuator(s) contained in the door latch unit and simultaneously grounds the other side of the door lock actuator(s). This completes the door lock actuator circuit, causing the door lock actuator(s) to rotate a cam assembly in the opposite direction, which then unlocks the door(s). The 12 volts which the central security module provides to the door lock actuator(s) are provided to each door lock actuator from the individual pins on the central security module connector. Keyless Entry When a remote transmitter button is depressed, it transmits the appropriate command to the central security module as a radio frequency. The central security module receives the command from the remote transmitter through an antenna, which is incorporated in the central security module. When the central security module receives a command from the remote transmitter, it then sends the appropriate output to control the desired devices. These outputs devices include:
  • The front and rear door lock units.
  • Central timer module (CTM).
  • The liftgate release motor.
  • The right and left side turn signal lamp(s).
The central security module sends a signal to the CTM when courtesy lamp illumination is required. Computer Operated Locks Each front door lock actuator contains a bipolar motor that controls the lock and unlock linkage. The lock/unlock lever of both front door interior handles use linkage to actuate the lever lock switch located inside each front door lock actuator. Each lever lock switch remains in the unlock position until lock/unlock lever of the interior door handle is moved to the lock position. This action toggles the lever lock switch to the lock position. The central security module uses only one electrical input for both lever lock switches. The central security module cannot determine whether the driver or passenger door lever lock switch was actuated. Therefore, actuating the lock feature from either front door will have the same affect of locking all doors. Actuating the unlock feature will not unlock any other door. The door lock control switches for both front doors also use only one input to the central security module. Both rear passenger doors contain a rear door lock actuator that controls only electric lock or unlock of the door. Actuating the lock/unlock lever at either rear passenger door will have no effect on other doors. The panic feature of the remote transmitter sounds the vehicle horn when the vehicle is not equipped with anti-theft. If the vehicle is equipped with anti-theft feature, a separate horn is sounds for the panic feature.
6/6/2022 10:57:09 PM • 2001 Ford Focus • Answered on Jun 06, 2022
4answers
Ford focus reversing lights stopped working
Probably sorted by now but in case anyone gets the same problem. Check all the red fuses in the main fuse box, not just the one the handbook says it should be. The main fuse box is behind the glove box...push in the sides and the gb will drop down....the fuse box is facing you.
1/15/2022 1:02:01 PM • 2001 Ford Focus • Answered on Jan 15, 2022
I need a wiring diagram
why do you need the diagram? Do you want to know which fuse is for what? that is on the inside of the fuse box door
11/27/2021 7:15:22 PM • 2001 Ford Focus • Answered on Nov 27, 2021
2answers
Door ajar 2001 ford focus zx3
check the wire on the the switch by removing it normally two or three screws hold it in place,if wires are tight remove them and replace the switch unless you can adjust the plunger
9/29/2021 4:30:10 PM • 2001 Ford Focus • Answered on Sep 29, 2021
Front drivers seat won't recline and its stuck
I just had the recline of my driver seat go out today. What happened to mine was the interior plastic of the handle that wrapped around the release mechanism fell apart all I had to do was take the handle off. I used a small Crescent wrench to to pull the lever mechanism towards the trunk. The same direction the handle would of pulled it, and it made the chair recline I got it set to where I liked it and now I'm just going to use some bondo and put the handle back on. Most fixes doesn't require the entire assembly to be replaced and taking it to the dealership will just have them charge you for the entire price for the system regardless of how simple of a fix it actually was. I have saved my self thousands of dollars doing simple fixes my self, and if you have even the slightest amount of intellect you can do it too.
7/28/2021 10:33:13 PM • 2001 Ford Focus • Answered on Jul 28, 2021
2answers
Were is the gem module 2002 ford focus
Your all wrong, it is behind the glove compartment, slightly up and to the right. I've installed and programmed dozens of them.
7/7/2021 10:06:40 AM • 2001 Ford Focus • Answered on Jul 07, 2021
B2159 "Memory #1 Output Short to ground
most likely you may have water in the ecu.ther is a 3 amp fuse in the fuse box .this is the memory for the engine control unit.chek to see if this has blown.
5/8/2021 9:37:27 AM • 2001 Ford Focus • Answered on May 08, 2021
I have two problems with my Focus 2001 ZTS, one is
check your front links ,control arm bushings ,ball joints ,sway bar bushings
3/25/2021 11:58:29 AM • 2001 Ford Focus • Answered on Mar 25, 2021
4answers
My 2001 ford focus dies while driving then i pull
Replace the fuel pump in gas tank and install a new gas filter
11/30/2019 11:46:21 AM • 2001 Ford Focus • Answered on Nov 30, 2019
2answers
2answers
Why is there a clunking noise during gear shift in my 2001 focus automatic?
Sounds like a worn gear linkage, If its the 2nd and reverse other than that its the Synchro inside the gearbox, either way sounds like a gearbox off and back on. You can determine the above if you got it looked over by a mechanic thou to be honest theres not much an answer but a rough idea.
10/1/2019 6:26:23 AM • 2001 Ford Focus • Answered on Oct 01, 2019
I have a 2001 Ford Focus 1.4 cl and the engine
Sounds like a vacuum leak, PCV hose or another vacuum hose leaking
10/1/2019 6:00:03 AM • 2001 Ford Focus • Answered on Oct 01, 2019
My dials, my speed dial
I'd definitely check battery and battery cables. In the past, I had a vehicle where the lights at night would brighten and dim a little on their own, drove me crazy, at the moment, I can't remember if battery or battery cables, one or the other. Just my opinion.
10/1/2019 5:59:29 AM • 2001 Ford Focus • Answered on Oct 01, 2019
2001 ford focus zx3 headlights wont work after fixing an electrical problem
Do you know what a wiring diagram is for ? How to use a DVOM - digital volt ohmeter to test electrical circuit's ? None of the headlamps work ? hi or lo beams ? Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info. Year , make , model an engine size. Under system click on lighting , then under subsystem click on headlamps . Click the search button then the blue link . Looking at the diagram i see fuse's light switch , multifuction switch , relay's - hi & lo an the headlamp assembly's . Now watch this video Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
10/1/2019 5:58:01 AM • 2001 Ford Focus • Answered on Oct 01, 2019
3,753 questions posted
Popular Products
2000 Ford Focus
2000 Ford Focus
3,749 Questions
2003 Ford Focus
2003 Ford Focus
2,055 Questions
2005 Ford Focus
2005 Ford Focus
1,226 Questions
2004 Ford Focus
2004 Ford Focus
897 Questions
2006 Ford Focus
2006 Ford Focus
840 Questions
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
View Most Popular
Focus Ford
  • Focus Ford
Most Popular Question
2001 ford focus se five speed automatic
  • Cars & Trucks
