20 Most Recent
Ariston Technologies LBE12X Ariston Questions & Answers
My ariston stalls during wash
This sounds very much like the belt is slipping. Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out to be a worn and inefficient motor, it is false economy to just have the brushes changed. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished.
Hope this is your problem solved.
Good luck,
John C
2/27/2011 2:44:06 PM •
Ariston...
Answered
on Feb 27, 2011
Fabric softener compartment problem.
Squeee, It's been more than a year since you posted this so I guess you must know the answer. It sounds like a Visit from an engineer(?)
I've got exactly the same problem with a Servis Easilogic 1500 and would appreciate knowing what you had to do to resolve the issue.
7/5/2007 12:17:41 PM •
Ariston...
Answered
on Jul 05, 2007
Ariston LBE12X will not fill
depends which program you started with
if you started with drain or spin then the humming noise you heard is the pump energised but jammed. remove the filter again and check nothing stuck in the pump impellor - bits of bra wire are the favourites
if you started with a wash or rinse program, the humming noise is the inlet valve energised but no water coming thro. check water is turned on and hoses not kinked
5/22/2007 10:19:36 PM •
Ariston...
Answered
on May 22, 2007
Smelly machine
problem is probably tjhat liquid detergent has been used - gives a smell loke drains. put on a boil wash without detergent and use powder detergent
4/5/2007 11:54:27 AM •
Ariston...
Answered
on Apr 05, 2007
My washing machine (model AQXL
when I wash heavy stuff it will not spin properly because the weight is not distributed evenly over the load and it stops every time. you may need a repair man unless you can just move the dial to a drain spot rather than spin, if enough water gets out it will probably open then.
6/15/2018 4:36:35 AM •
Ariston...
Answered
on Jun 15, 2018
