20 Most Recent
Dynex 30-Pin Dock Adapter for Apple iPod shuffle Questions & Answers
What does the little electrical bolt symbol mean?
this is obviously a power or connectivity issue,
check that the device ( your ipod ) is correctly seated into the logitech speaker system, and check the power cables are connected according to the manual which came with the logitech speaker system.
question u may ask yourself? - does the ipod work as it should on its own? (without non-apple devices/components attached to it) - if it doesnt - take to an apple store or call or seek apple support.
it sounds like your ipod is low on power from source.
i hope this directs you in the right direction, party on!
My screen will not turn on even tho there is power?
Just repaired this TV today. You will need to purchase the inverter board. The TV will power up....you will see "PLEASES WAIT", and disappear, you have a black screen. When you remove the back cover, look to your left. You will see a long vertical board. That is the board you will replace. Seek shop jimmy, enter model number of your TV. You will see an inverter board for $24.95 plus $9.50 shipping. Thanks for asking me, Matt of Martins TV Repair.
We cannot get the sound
I think this is the model, or close to it.
http://downloadcenter.samsung.com/content/UM/201009/20100906145211281/[UC5000-ZA]BN68-02625A-03Eng-0903.pdf
Page 11 talks about audio out.
The actual model of the Dynex would be useful.
Maybe you could get it to come from the actual audio source, like the Cable Box, which has really good audio options while TV's usually don't and add nothing to the sound by being in the loop.
Tried to use mic, only picking up computer sounds.
Ensure that you have selected the Microphone or the Line-in as your recording input. It sounds like you have set STEREO MIX as the recording input. Double click your speaker, select from the drop down "Properties" then Adjust volume for (RECORDING) select that and ensure that your appropriate recording device is selected. (XP)
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
