20 Most Recent Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer Questions & Answers
My fridgidaire affinity dryer starts
Take your receipt and warranty papers back to where you purchased it. They should be able to help you.
3/4/2018 1:08:03 AM • Frigidaire... • Answered on Mar 04, 2018
7answers
My frigidaire affinity dryer displays LOC
Hi, "LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
1/13/2018 9:15:41 PM • Frigidaire... • Answered on Jan 13, 2018
2answers
How do I stop the buzzing noise when in heating cycle?
BAD IDEA THERE IS A REASON IT IS BUZZING? FIND THAT OUT FIRST
3/31/2016 4:07:45 AM • Frigidaire... • Answered on Mar 31, 2016
What do error codes FDL and R11 indicate?
Hello Lidia, thank you for your inquiry! Based off the information you have provided your Frigidaire dryer is not heating and displaying error codes "FDL" and "RL". I am showing that the codes you have provided are not valid error codes. I would recommend performing a reset on your dryer and you can do that by disconnecting power from it for at least ten minutes. I see that you have already replaced the igniter; however, if you continue to have issues with the error codes I would suggest having a professional technician out. This will help you avoid any further unnecessary part purchases. Hopefully this information is helpful to some degree. -Matt
2/17/2016 5:53:29 PM • Frigidaire... • Answered on Feb 17, 2016
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
11/23/2015 12:18:24 AM • Frigidaire... • Answered on Nov 23, 2015
2answers
Error 61
Looks like E61 is a heat relay related.Does the dryer heat OK?
6/16/2015 3:51:59 PM • Frigidaire... • Answered on Jun 16, 2015
Frigidaire gas dryer
Gas Dryer no heat: or shuts down soon after heating CHECK: Thermal Fuse If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement. Igniter and Gas Valve Coils TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ? Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant. Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit. Air Flow and Heat The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all. Warning There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
4/22/2015 10:58:35 PM • Frigidaire... • Answered on Apr 22, 2015
Frigidaire affinity dryer yes code
heres how to get them :
READING ERROR CODES
1. Rotate cycle selector knob to the 3 O'clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O'clock position. The four indicator lights of Drying, Cool Down, Wrinkle Rid
(Press Saver), and Clean Lint Filter will flash the number of times for the first digit of the code and the START indicator
light will flash the number of times for the second digit. Take separate counts of each indicator light, then repeat to
confirm in order to be accurate in identifying the proper error code. The code is obtained by counting the number of times
the lights flash. Example E24: The four indicator lights would flash twice indicating the 2 and the START indicator light
will flash four times indicating the 4. The four indicator lights and the START indicator light start flashing at the same
time. The control will pause for 2 seconds, then repeat the code.
NOTE: A letter appearing in the code stands for a number higher than nine. A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. The four indicator lights would blink four
times and the START indicator light would blink ten times. Troubleshoot the problem by using the chart below.
To move on to the next code, press the OPTIONS button.
To clear code, press the Select button. Code will be cleared when mode is exited.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
Error Code Label Description Solution
E10 General EEPROM
Fault
Problem with communication
between EEPROM and the
microprocessor.
Clear code, exit mode and start dryer. If problem persists, replace electronic
control.
E11 Checksum Error Problem with communications or
memory did not check, one has
become corrupted.
control.
E12 Non fatal R/W
error
Problem reading or writing to the
memory or input/output.
control.
E24 Control NTC Short
Circuit
Control thermistor or its wiring is
shorted.
Remove wires from control thermistor. Measure resistance of thermistor. If
reading is not 50 K (± 10%), replace thermistor. If reading is within 50 K (±
10%), check wiring between thermistor and electronic control. If good,
replace electronic control.
E25 Control NTC Open
Circuit
open.
E4A Program Timeout
Fault
The drying time has exceeded
program time for that cycle.
Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes.
Position cycle selector to NORMAL, temperature selector to HIGH HEAT
and touch START. Check for anything that would extend dry times such as:
no heat, restricted vent, blower fan blade broken or loose, dryer installed in
closet with solid door, or bad connection in moisture sensor bar circuit or
dirty bars. If dryer operates normally but code returns, replace electronic
control.
E5B Heater Fault (no
heating)
Temperature reading of control
thermistor has not changed in a
certain amount of time.
and touch START. Measure voltage across terminals on relay RL2 (heater
relay) on electronic control. If meter reads 240V on electric models and
120V on gas models, replace electronic control. If meter reads zero, remove
power from dryer. Disconnect wire going to NO terminal on the relay RL2.
Reconnect power and measure voltage drop between terminal COM on
relay RL2 and neutral. If meter reads zero, wire between incoming line and
relay RL2 is open. If meter reads 120V, check the rest of the heater circuit.
E68 Key (button) Struck
Fault
One of the keys (buttons) is stuck
closed (active).
Enter function test mode and perform key (button) test to determine which
button is at fault. Carefully free the and perform the test again. If button is
free but the key struck code still exists, replace electronic control.
E8C Too many trips in a
period of time.
The safety (high limit) thermostat
has tripped too many times within
a certain period of program time.
Check for blocked lint filter, blocked exhaust, air leaks around air duct,
broken blower fan blades, worn or loose drum seals, dryer installed in closet
with solid doors or door seal not correctly seated.
EAF Watch Dog Reset Microcontroller has been reset by
internal Watchdog timer. Clear code, exit mode and start dryer. If problem persists, replace electronic
4/21/2015 11:01:59 PM • Frigidaire... • Answered on Apr 21, 2015
My frigidaire affinity front load gas dryer has a banging noise when it runs
you;ll have to examine it closely with a good flashlight to see if u can detect any gaps in drum to front cover (front and back), seam should be even all the way around if not it's gonna be out of balance and hit at points in its rotation , ive seen every thing from baby socks to necklaces get in there and mess it up
4/21/2015 10:58:54 PM • Frigidaire... • Answered on Apr 21, 2015
Buzzing sound
USUALLY WHEN MOISTER SENSOR DETECTS CLOTHES ARE DRIED THE BUZZER GOES OFF TO LET U KNOW SO MAY HABE BAD MOISTER SENSOR, UNLESS THE CLOTHES ARE DRYED WHEN IT GOES OFF
12/20/2014 6:25:46 PM • Frigidaire... • Answered on Dec 20, 2014
How do I replace igniter on frigidaire gas dryer
Hello friend, thanks for your post!
Based off the information you have provided you are looking to replace the igniter on your Frigidaire dryer. These intricate parts do require precision and patience, therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Matt
10/2/2014 6:46:07 PM • Frigidaire... • Answered on Oct 02, 2014
Is model and serial number located anywhere besides door opening?
It is located in the inside if the door
9/29/2014 5:06:14 AM • Frigidaire... • Answered on Sep 29, 2014
I am getting e4a on my gas dryer
Good Afternoon Friend, this is Z. Thank you for your post! Typically error code E4A indicates that your Frigidaire dryer is experiencing a program timeout fault or max time has exceeded for that cycle. A professional normally checks for anything that would extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closed with solid door, faulty connection in moisture sensor bar circuit. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair your dryer. Hope this helps!
8/12/2014 7:56:50 PM • Frigidaire... • Answered on Aug 12, 2014
Is there a reset button for Frigidaire AEQ7000EGO? Had a power surge/outage and now dryer has no power, although plugged into electrical outlet.
Good Morning Friend, I understand you had a power surge at your home, and now your Frigidaire Affinity dryer, model#, AEQ7000EGO, has no power. I do see that you have checked to make sure that it is plugged in. I suggest checking the circuit breaker or fuse that the dryer is on. Make sure that the fuse is not blown or the breaker tripped. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful. -Best Regards- WP
6/30/2014 1:52:13 PM • Frigidaire... • Answered on Jun 30, 2014
How to reset control board on Frigidaire affinity gas dryer
Hi Friend, thank you for your inquiry! I understand your Frigidaire dryer is experiencing a shutoff issue. It is possible that you may either have a communication error from the main control board or the timer itself may not be operating correctly. Let's try resetting your dryer by either unplugging it or flipping the household circuit breaker to the off position. It is best to wait roughly ten minutes and then turn on your dryer. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, you may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you. Best regards! - Z
6/10/2014 4:14:35 PM • Frigidaire... • Answered on Jun 10, 2014
How much is a control board for a fridaire affinity dryer?
Hello Friend, thank you for allowing me to assist you! I see that you would like to know the pricing of a replacement control board for your Frigidaire dryer. May I please have your model number? The serial tag, which lists your model number, is typically located on upper front as you open the door. With this information I can better address the issue at hand. In the meantime, error code E66 is associated with the heating element relay. A technician would typically check the ohm resistance of the relay to determine if it is the cause of the error code. If the readings are incorrect, the heating element more than likely needs replacing. If the readings are incorrect, it could potentially be the main control board. This is not a normal DIY job so you may want to connect with a local technician to determine the exact diagnosis. I hope this helps! - Z
5/25/2014 8:14:20 PM • Frigidaire... • Answered on May 25, 2014
Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer Logo
133 questions posted
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Dryers
  • Frigidaire Dryers
Most Popular Question
power off
  • Dryers
