20 Most Recent PNY 4GB USB 2.0 Flash Drive - Grey/Black Questions & Answers
the computer is not seeing it properly un plug,then refit ,are the contacts clean,
PNY 4GB USB 2.0... | Answered on Oct 13, 2018
Best to contact your dealer.
PNY 4GB USB 2.0... | Answered on Dec 13, 2016
If the pen drive is not recognize in any PC, that's it, it's damage and there is no way to recover anything from the pend drive, sorry. Being there.
PNY 4GB USB 2.0... | Answered on Jul 10, 2016
Hello,You need go to www.malwarebytes.com and do the free download and scan everything.
PNY 4GB USB 2.0... | Answered on Sep 28, 2015
it may have viruses so you should format this flash NTFS or FAT32
PNY 4GB USB 2.0... | Answered on Mar 09, 2015
Copy and paste or drag and drop to the stick.
PNY 4GB USB 2.0... | Answered on Aug 17, 2014
this flash is write protected by a pass word
PNY 4GB USB 2.0... | Answered on Aug 04, 2014
To disable the write protection:
    1.From the Start menu, click "Run", type "regedit", and press <Enter> or click <OK>.
    2.Navigate to HKEY_LOCAL_MACHINE > SYSTEM > CurrentControlSet > Control > StorageDevicePolicies.
    3.Double click on "WriteProtect" and change the value to 0 (WriteProtect = 0 for disabled; 1 for enabled).
    4.Close the registry editor and restart Windows.
    5.After Windows starts, test writing to your USB drive.
    Important Note:
    Serious problems might occur if you modify the Windows registry incorrectly. **PLEASE** make sure that you follow these steps *exactly* and *carefully*. For added protection, back up the registry before you modify it in case you have trouble so it can be restored.
    For more information about how to back up and restore the registry, follow the steps as in the KB Article: http://support.microsoft.com/kb/322756/
PNY 4GB USB 2.0... | Answered on Apr 30, 2014
Go to Start
Click Right mouse button on Computer
Click on Manage
Click on Disk Management
In the Right Panel of the drive you wish to fix
Click Delete Volume
When Volume is deleted
Click Create Volume
Follow the steps
For small drives use Fat32 not NTFS
NTFS is not portable between XP and Win 7
You may also have a virus.
PNY 4GB USB 2.0... | Answered on Apr 14, 2014
Usually there is a small switch or colored slide which flips between write protected and writable. If there is no switch it may be the software that is on the drive is preventing the format, if this is the case you may need to use a boot disk like Hiren's boot Cd to format it while not booted into Windows.
Plug the flash drive in your computer.
Then go to the Cmd Prompt, RunAs Administrator,
Then type Diskpart >
To list all the available Disks, type List Disks. You will see all the drives listed with a number ID. So the flashdrive might be Disk 3, or whatever.
Now type Select Disk # (whatever the flashdrive # is)
Now type Attributes clear readonly.
Now type Exit, to leave the diskpart applet
That should do it.
PNY 4GB USB 2.0... | Answered on Apr 06, 2014
Hi there !
Just connect your usb flash disc into a usb port of your computer. Then right click mouse and you will see the FORMAT command there. Just run it and it will format your USB flash disc.
PNY 4GB USB 2.0... | Answered on Mar 19, 2014
When you deleted files and folders on your flash drive, they don't goes to trash. Deleting won't make them erase permanently. Those deleted files and folders are still stored on your flash drive, they're just invisible or inaccessible. You can recover deleted files from flash drive with flash drive recovery software. I had succeed with Tenorshare Data Recovery.
Anyway, you can download it and scan your flash drive for free to preview whether you can recover your files. It will show you the file name, type, date and size of your files and thumbnails for your pictures that it found on your drive.Get it from http://www.any-data-recovery.com/product/datarecoverystandard.htm
PNY 4GB USB 2.0... | Answered on Aug 06, 2013
memory card kagaon?
PNY 4GB USB 2.0... | Answered on Jul 15, 2013
It may be broken, but I've found that you can get a repair for a non-appearing pen drive by using the wonderful software called photorec bundled in the testdisk software.
(http://www.cgsecurity.org/wiki/TestDisk_Download)
PNY 4GB USB 2.0... | Answered on Jun 13, 2013
PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
223 questions posted
Top PNY Electronics - Others Experts
Marvin
Marvin
Ekse
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • PNY Electronics - Others
Most Popular Question
re using flash drive
  • Electronics - Others
