20 Most Recent
Sony ACID Music Studio 7 Questions & Answers
I have a Fostex DMT-8vl 8 track digital recorder.
You can copy. You cannot just dump the file data. Unless you have an audio interface with multiple inputs, you can only copy 2 tracks at a time. Also, to sync the timing you'll need a midi port on the computer. Then you make the computer the "master" and the Fostex a "slave" device.
Acid pro7.0 serail number
if you paid for the program contact sony in australia and they will help you out. i have also found that if i don't use mine for sometime i have to reregister it. bit ridiculous
Need serial code
It is advised you download a fresh copy of the program online and if you want to, you can make use of your previously existing installed version but use the keygen included in the fresh downloaded folder.
To do this, you have to use torrents. This can be done by
1.
You have to go to www.bittorrent.com
2. Download and install the
torrent program from that website.
3. Make sure your antivirus does
not prevent the program from connecting to the internet.
4. After the
installation, you can go to the link below and click the download
.torrent button when the page opens. The file is less than 1 MB.
http://isohunt.com/torrent_details/90234001/ACID+Music+Studio+7?tab=summary
5.
After you download the file, you have to open the file using the
bittorrent program you downloaded first.
6. It might take a couple of
days or less depending of the speed of your internet. All you have to do
is to be patient and monitor the torrent program from time to time to
monitor the progress of your download.
Also, you can turn your
computer on and off whenever you want and the download would continue
from where it last stopped.
If you have any questions, please comment
here.
Thank you for using FixYa.
5.
here.
I have a toneport line 6 and Gearbox...can't
Hi! First of all, please check Sony Acid Home Studio if its compatible with your windows 7. I would suggest you to reinstall Acid Home Studio for there may be corrupted files on the program that makes it shut down. Hope this helps. Have a good one!
I need a serial number 4 acid pro 7.0
if you didint get one when you bought this product then take it back and demand you get one if you have lost the one that came with it then phone the number helpline number and speek to them i think the only other thing you can do is buy on some underhanded ppl use a torrent to obtain this numbers but i cant condon the use of torrents like
www.btjunky.com as there against the law to use hope this helps
My microphone isn't working
Hi ,
Test the record function on the notebook PC
Click Start
, then Programs
, Accessories
, Entertainment
, and then Sound Recorder
Click Record
(the red dot) and speak into the microphone.
When you are finished recording, click Stop
(the gray rectangle).
To play back the recording, click Play
(the gray arrow pointing to the right).
- If the recording does not play back, continue to the next section of this document.
Step 2: Checking microphone settings
Click Start
, then Programs
, Accessories
, Entertainment
, and then Volume Control
.A Volume Control or Master Volume window opens.
Click Options
, and then Properties
Select Recording
, and make sure Microphone
is selected.
Click OK
. The Volume Control window should change to a Recording Gain Control window.
Click Options
again and then click Advanced Controls
. If Advanced Controls
is unavailable, then an alternate microphone is not available. Proceed to the next series of steps.
Remove the check next to Alternate microphone
, click Close
, and test the microphone. If there is still no sound, continue to the next step.
Step 3: Ensuring the correct recording device is selected
- Access sound properties:
In Windows XP, to access the sound control panel applet, click Start
, then Control Panel
. Click Sounds, Speech, and Audio Devices
, and then click Sounds and Audio Devices
In Windows 95, 98, and Me, click Start
, Settings
, and Control Panel
. Double-click Sounds and Multimedia
, or Multimedia
. The Sounds and Multimedia Properties window opens.
Click the Audio
tab.
Under Sound Playback
, select the audio device that is installed on the computer (there should be only one).
Under Sound Recording
, select the audio device that is installed on the computer. It should be the same as the listing under Sound Playback
Click OK
- Close the Sound and Multimedia Properties window and test the recording. If there is still no sound, continue to the next step.
Kindly send me you valuable Feedback.
