20 Most Recent Whirlpool 24.8 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - White-on-White Questions & Answers
WHY IS FREEZER COOLING BUT REFRIGERATOR IS NOT?
Look for ice build up on the back of the freezer panel. if there is ice or snow the defrost system has failed. if there is no ice then it could be a fan that has failed. Worst case is an inneffiecient compressor.
9/1/2014 9:01:45 PM • Whirlpool 24.8... • Answered on Sep 01, 2014
Refrigerator food is freezing
Lower the thermostat or using the other control reduce the flow of air from the freezer to the refrigerator portion.
11/28/2013 2:38:18 AM • Whirlpool 24.8... • Answered on Nov 28, 2013
I have a Whirlpool Refrig. model GX5FHDXVY04. The freezer is working properly but the refrigerator is not cooling. I noticed frost on the inside back panel of the freezer. I turned the temp down in th
Many of frost-free fridges use fans to move a controlled amount of air into the upper or side cooling chamber, check for non-working fan or a stuck or malfunctioning damper control. Keith L.
3/2/2012 4:30:11 AM • Whirlpool 24.8... • Answered on Mar 02, 2012
Ice maker/ water dispencer "locked"
have whirlpool ice and water waterand ice will not come come out--right no ice wil come push the ice have ice ill not go back to water
12/29/2011 3:45:39 PM • Whirlpool 24.8... • Answered on Dec 29, 2011
My freezer keeps stoping for about 40min every 6-8
Sounds like a defrost timer may be wearing out. When this happens sometimes the timer sticks in the defrost lobe on its cam . You will need to find the model number and then click here=> Whirlpool User Manuals and Part Manuals This site also has the parts manual for your model with part numbers on each following page. I will be here to assist you or HERE if needed, Thank You, Sea Breeze
If helpful please rate this solution.
sea_breeze_273.jpg Appliance Model Number Locators
Refrigerators
10/30/2011 1:36:57 AM • Whirlpool 24.8... • Answered on Oct 30, 2011
I have recently purchased a Whirlpool Gold
hello cathy, Depending on where the actual snow is located if it were against the rear freezer wall then you would have a defrost issue in which either the defrost thermostat, the defrost heater, the defrost timer has a fault these parts can be checked by doing a continuity test on them with a multimeter to assure they are functioning properly. If you can message me back the model number i can most likely find your schematic for your machine and point out where each piece is located. On some newer units they do not have a defrost timer instead they have a adaptive control board which takes the place of the timer before you do any checking of these parts it is most important to also assure that you have no rips or tears in the freezer door seal. although if you did you would see the ice build up more towards the door instead of on the rear of the freezer wall. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks Rick
p.s you would have to remove the screws that hold the rear panel in the rear of the freezer which would give you access to the evaporator coil and the defrost thermostat and the defrost heater if when you do remove the panel you see the evaporator coil with ice build up on it you would have to defrost the ice with a hair dryer and then conduct your tests this ice build up is a definite sign of a defrost issue Thanks again I await your reply Rick
10/16/2011 9:13:03 PM • Whirlpool 24.8... • Answered on Oct 16, 2011
Clogged drain plug whirlpool imperial
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
10/5/2011 12:27:34 PM • Whirlpool 24.8... • Answered on Oct 05, 2011
Whorlpool refrigerator over heated and not cooling
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
Be sure the BACK COVER is in place and hasnt been accidently removed.
MORE TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS____
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Leo Ponder
imufo2
Most overlooked dryer energy saving problem EVER!
http://www.fixya.com/support/r5739846-most_overlooked_dryer_energy_savingr
REF THERMOMETERS TIPS
http://www.fixya.com/support/r10177561-second_biggest_refrigerator_energy
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
10/4/2011 2:38:13 AM • Whirlpool 24.8... • Answered on Oct 04, 2011
Whirlpool 24.8 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - White-on-White Logo
74 questions posted
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
ice maker water dispencer locked
  • Refrigerators
