IE:youtube downloader you might have to try a few times to get it right
hope this helps
error 43 is a usb universal serial bus controller problem click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question / exclamation mark? ! or a red X right click to reinstall drivers or if you can see your usb drive but its not working ports(com&lpt)right click update driver
for windows 7 you might try
First, please disconnect all USB devices. Then, go through the following steps:
1. Press "Ctrl + Esc" to open the "Start" menu.
2. Type "devmgmt.msc" in the Search bar and press "Enter". Click "Continue" if necessary.
3. In Device Manger, press Tab and use "Up" and "Down" to move the highlight to "Universal Serial Bus Controllers".
4. Press "Right" and expand it.
5. Press "Down" to move to the first item and press "Delete" to remove it.
6. Repeat the step 5 and uninstall all items under "Universal Serial Bus Controllers".
Then, restart your computer and Windows 7 will reinstall all controllers automatically.
hope this helps
A few important bits of information about using faults and possible fixes on usb drives
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
ports(com&lpt)right click update driver if this fails to fix the problem check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box (I have found better results ticking the first box then reurn and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive also you might need to do this
click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing
permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XPalsoIf you are running a Windows XP OS then you might be able to: click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control.
if you need more help with this post a replyhope this helps
140 questions posted
405 Questions
322 Questions
0 Questions
7 Questions
0 Questions
