20 Most Recent
Bushnell Waterproof Binoculars Questions & Answers
The diopter setting eyepiece has come out of the
The entire diopter setting eyepiece was off.I separated the eye cup from the rest of the diopter setting eyepiece,
and aligned the channel guides on the lens piece to slide it into place.
Then holding it in place, taking care not to gum up the lens,
I experimented with how to screw in the retainer
ring so that its white dot registered correctly. Finally reattach the eye
cup and focus. It's like new!
4/11/2010 10:26:41 PM •
Bushnell...
Answered
on Apr 11, 2010
Eyepiece assembly bushnell telescope
You never told us what model number or telescope TYPE you own. Is this a refractor or a reflector. ???
If a REFRACTOR usually you have a diagonal, the diagonal goes into the focuser and then the eyepiece goes into the diagonal.
On a REFLECTOR the eyepiece goes directly into the focuser.
Bushnell Tour v3 laser rangefinder will not display yardage
Please shutdown your device for 5 minutes, booot up and then check for yardage again. If this does not work, then you might look into the device manual (in troubleshooting) to check for an alternative approach to fixing this. Thank you.
