20 Most Recent Bose Companion 3 Series II Multimedia Speaker System (3-Piece) - Graphite/Silver Questions & Answers
How do i hook-up a bose companion 3 series II system to an hdtv?
What type of connections does your tv have, hdmi, component? Match up the connection from the bose series 3 to your hdtv. I don't want to assume that your tv has hdmi, which would provide the best signal throughput & quality.
11/14/2018 2:02:02 PM • Bose Companion 3... • Answered on Nov 14, 2018
When ever I turn on
Static sounds usually indicate a failing connection. Disconnect and reconnect the plug several times to shine the contacts on the pins.
6/26/2017 4:17:54 AM • Bose Companion 3... • Answered on Jun 26, 2017
Blown Fuse and Need to replace
For technical help Call Bose.: 1-800-380-4831 Mon. - Fri., 8:30 AM - 9 PM ET Sat., 9 AM - 6 PM If you're not in North America see this site: http://worldwide.bose.com/productsupport/en_us/web/home/page.html
6/5/2016 11:45:16 AM • Bose Companion 3... • Answered on Jun 05, 2016
No sound coming through, drumming
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps don
6/12/2015 1:58:04 AM • Bose Companion 3... • Answered on Jun 12, 2015
Our bose companion 3 series 11 control pod is missing. Can the speakers be used without the pod? Is there a generic pod we can get?
The control pod has specific design for the product thereforeI don\'t think there is any generic pod that comply with the product, though you can find control pod for bose in ebay for about $10 to $5071626100888?pt=US_Computer_Speakers&hash=item27f5b67898">http://www.ebay.com/itm/Bose-Companion-3-Series-II-Control-Pod-/171626100888?pt=US_Computer_Speakers&hash=item27f5b67898
6/12/2015 12:22:24 AM • Bose Companion 3... • Answered on Jun 12, 2015
2answers
What can cause loud humming?
how to connect bose 5.1 to mixers
1/18/2015 4:00:14 AM • Bose Companion 3... • Answered on Jan 18, 2015
0answers
3answers
I have a bose companion 3 series ii my base
Yes you can fix it but need a soldering iron and tin and the part that will change. Get everything in radio shack or similar store. If you don't now how solderin go to this link: http://www.youtube.com/watch?v=Rm28jkKGMz4
Good luck
7/31/2014 11:16:04 PM • Bose Companion 3... • Answered on Jul 31, 2014
Bose Companion 3 Series 2 Multimedia doesn't work.
Maybe a tranformer burnout, this is the most common cause, refer to a Bose service center
6/23/2014 7:20:15 PM • Bose Companion 3... • Answered on Jun 23, 2014
3answers
Sound is coming out of only one speaker, with both
have same problem - swapped speaker leads and sound comes out of other speaker
3/11/2014 10:42:30 AM • Bose Companion 3... • Answered on Mar 11, 2014
After listening to several songs my volume in my Bose computer speakers start pulsating. Going up and down, it is suttle but it drives me crazy!!
The laser is failing. Just like in a record player there is a tracking gain adjustment inside but it is very touchy to move it. If anything is adjusted inside it may never work again. Perhaps resoldering some of those potentiometers, and perhaps other spots on the board may fix this. If the laser fails it is done.
11/13/2013 2:14:45 PM • Bose Companion 3... • Answered on Nov 13, 2013
Bose Companion 3 Series II Multimedia Speaker System (3-Piece) - Graphite/Silver Logo
Popular Tags
56 questions posted
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Bose Audio Players & Recorders
Most Popular Question
our bose companion 3 series 11 control
  • Audio Players & Recorders
