20 Most Recent PNY Attach? 1GB USB 2.0 Flash Drives (3-Pack) Questions & Answers
Try the drive in another system first.
If it works in another computer, the problem is either your computer or the operating system
If it doesn't work in another computer, then contact the manufacturer.
These drives have a 1 year warranty, so you should be OK to return it for replacement if it's defective.
PS - it's spelled Attache (this will make it easier for you to search for it on their website)
PNY Attach? 1GB... | Answered on Feb 22, 2011
Hi
Please follow these steps
1. I think its not a problem with flash drive.
2. There should be virus in your computer.
3. Please install anti virus or if it is already there update it.
4. I think that virus is deleting your files in the flash drive.
PNY Attach? 1GB... | Answered on Jul 31, 2010
for example if ur pendrive takes H drive positiion than type h:/ in the url ofmy computer ,than it opens
PNY Attach? 1GB... | Answered on Mar 16, 2010
clean dust inside pin and insert ,refresh sys twice ,go to control panel check for external devices and get it
PNY Attach? 1GB... | Answered on Sep 06, 2009
open my computer then right click on pendrive like g: h: and click on format
on format option click quick format and click start then finish it anc check it
thanks
rate me
PNY Attach? 1GB... | Answered on Sep 28, 2008
Did you format it to FAT32 before you placed music on the card?
PNY Electronics... | Answered on Jan 16, 2019
The flash drive may need to be REFORMATTED. In some cases, the flash drive is pulled out from the USB port incorrectly. That can lead to a damaged Flash Drive.
Always remove Flash Drives by using the EJECT method.
To format the USB Flash drive, go to the File Explorer (the bottom row of Icons on the computer screen showing a manila folder inside a holder) and locate the USB drive by letter, such as drive B,C,D, etc. One of these letters or higher. Tap the corresponding to the USB drive and an option box comes up. Select "Format" (Quick is ok). Once formatted, the drive is ready to accept data once again. If it cannot be formatted, then the USB DRIVE may have sustained damage to the circuit and no longer can be of service.
PNY Electronics... | Answered on Feb 05, 2018
Google cloud.
PNY Electronics... | Answered on Oct 17, 2017
hi buy a card reader cost about $5 dollars on E/BAY plug it into youre mac & put the sd card in & hope it all works ...cheers..
PNY Electronics... | Answered on Apr 06, 2017
The Elite X has faster read/write speeds (and is more expensive). Otherwise there is no functional difference.
Turbo Attache 4 specifications
https://www.pny.com/turbo-attache-4-usb-flash-drive-black
Elite X specifications:
https://www.pny.com/elite-x-usb-3-flash-drive?sku=P-FD256EX-GE
PNY Electronics... | Answered on Apr 02, 2017
Make sure nobody put hidden files on the Flash,
Copy the files off, then reformat the flash in NTFS unless you have an old computer.
FAT32 will work, the limit is 4GB for a single file and 2TB for the whole drive. If it was an SD or variation I would have kept with this for compatibility with cameras ect. NTFS for a USB has a couple features that make it slightly more reliable and faster for a situation where you have many small files.
Below is a link to a simple flash formatting tool.
HP USB Disk Storage Format Tool
PNY Electronics... | Answered on Jul 31, 2016
no it cannot work
Dell N5010 is a DDR3 memory
Correct spec speed is
DDR3-1066/PC3-8500
PNY Electronics... | Answered on Oct 20, 2015
You have to format the drive to the correct type before transferring your music onto it. Not sure whether you're using windows or Mac. In windows go into file explorer, right click the usb drive and select format. This will show you a section of formats including FAT32.
PNY Electronics... | Answered on Mar 01, 2015
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
PNY Electronics... | Answered on Dec 02, 2014
PNY Attach? 1GB USB 2.0 Flash Drives (3-Pack) Logo
8 questions posted
Top PNY Electronics - Others Experts
Marvin
Marvin
Ekse
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • PNY Electronics - Others
Most Popular Question
removable disk drive broke way
  • Electronics - Others
