20 Most Recent
Dynex 7-Port USB 2.0 Hub Questions & Answers
I plugged in a new
base from the description of your problem the issue now here is the Windows 7 system don't recognized the hub anymore, so what we can do here first is to unplug the hub and if your computer is a desktop connect the hub to the back USB port and then restart the computer after connecting it.
When my computer searches for
This device should be recognized automaticaly by the OS. There are some issues with Windows 7, though.
Make sure you are trying to plug it in a 2. USB port, rather than 1.1. This might cause you trouble (even though this will not be a problem if you have a new computer)
Connect the hub to the external powercord. Sometimes it is not recognized because the hub cannot drain enough energy from the port.
if you are using a desktop pc, make sure it is plugged in the rear usb ports and not at the ones up front.
refer to the manual for further assistance:
http://www.dynexproducts.com/cms/documents/DX-B4PORT-B7PORT_09-0962_QSG_V4_ENG_Final_lr.pdf
I need software for my 7 port hub i just purchased
No you don't. Just plug it in to a USB 2.0 port on your PC and it should find it all by itself. You make have a problem if you are plugging a USB 2.0 hub into a USB 1.1 port. Also, you may well want to use the external power supply as it may not be able to draw enough power from PC USB port.
Dynex 1.3mp driver update for windows 7
Unfortunately, Dynex no longer provides driver updates for their 1.3MP webcam on Windows 7 as the product has reached its end of life and is no longer supported. However, you may still be able to use the webcam with the existing drivers that came with it or with the generic drivers that are built into Windows 7.
To check if your webcam is recognized by Windows 7, follow these steps:
- Plug in your Dynex 1.3MP webcam to your computer's USB port.
- Click on the "Start" menu and select "Control Panel".
- Click on "Hardware and Sound" and then select "Device Manager".
- Look for the Dynex webcam under the "Imaging devices" or "Cameras" category. If it is listed, then your webcam is recognized by Windows 7.
If your webcam is not recognized by Windows 7 or is not functioning properly, you may want to try downloading and installing a third-party driver update software like Driver Booster or Driver Easy. These programs scan your computer for outdated or missing drivers and automatically download and install the latest versions for you.
Alternatively, you can try searching for a compatible driver on third-party driver download sites, but be cautious as some of these sites may contain malicious software. It is always recommended to download drivers from the manufacturer's website or from trusted sources.
Have a dynex optical mouse model # DX- PWLMSE how does it connect
The Dynex DX-PWLMSE uses a 27 MHz frequency wireless connection between the mouse and a specific USB receiver. For the specifications, see
https://www.dynexproducts.com/pdp/DX-PWLMSE/8632063 .
To use the mouse, you need to press the Eject button behind the scroll wheel. This lets you open the battery/USB storage compartment. Put two AAA batteries into the mouse. Then remove the USB adapter (it's between the two battery slots). Close the storage compartment and put the USB adapter into an available USB 2.0 slot on the computer with a version of the Windows OS above Windows 98. (Note: the specifications I see indicate Dynex wrote drivers for Windows Vista. It may not work with Windows 7, 8 or 10.) Make sure that the computer is on and can get driver updates from on-line sources. Turn on the mouse and it should auto-pair with the receiver. If there is no response, try pressing and holding the connect button on the bottom of the mouse.
I'm not aware of any vendors that sell the USB receiver for this mouse. The manual for the DX-PWLMSE is available from Manuals Lib:
https://www.manualslib.com/products/Dynex-Dx-Pwlmse-Wireless-Optical-Usb-Laptop-Mouse-4908.html .
I hope this helps.
Dynex DX-46L150A11
That could be the graphics card, power supply in either the monitor or the computer, motherboard or the monitor. You might try a different monitor as a test to try to narrow down the problem..
