20 Most Recent Duracell NiMH AA/AAA Battery Charger with 4 Rechargeable AA Batteries Questions & Answers
My Duracell battery charger has a blinking red
I had the same problem with flashing red lights. Both sides on a four battery charger. I swapped the batteries to another charger and the batteries were fine. They charged normally. I put some different batteries in the charger and the same flashing light situation. Those batteries also charged normally in a different charger. I looked closely at the back of the charger and, low and behold, "made in China". Why does that not surprise me. The bottom line, it may not be a battery issue.
9/26/2019 6:51:58 PM • Duracell NiMH... • Answered on Sep 26, 2019
I recently purchased a Duracell CEF14AU battery
Charging Normal Batteries runs the risk of explosion...
12/31/2012 2:44:01 AM • Duracell NiMH... • Answered on Dec 31, 2012
0answers
I charged my Duracell 2400 mAh batteries for 15
your lucky then,,, they take 16 hourse to fully charge unless you rapid charge them? a nasty thing to do to a new battery? all ways slow charge them first,,
never fast charge any battery only charge at whats called "the C10 rate!" they live much longer that way,
in other words slow charge when first charge,,,faster after that! ok,, did you not know you must "form the cells first" before you use them?
10/24/2009 7:34:09 PM • Duracell NiMH... • Answered on Oct 24, 2009
I bought KODAK NiMH 2400 mAh and it isn't
NiMH tends to have a "memory". What this means is that the batteries will get used to being only charged and discharged a certain amount. What could be happening is that the battery THINKS it is charged when it is not... or.. it THINKS it is discharged when it is not. You can try to recondition them:
  1. Charge them
  2. reset the charger and charge again
  3. put them in your device and drain them
  4. let them sit, drain them again
  5. recharge them
  6. drain them again
Do this a few times. If you don't notice an improvement, you may want to consider getting a new set of batteries - I would recommend lithium rechargeables.
7/12/2009 12:12:20 AM • Duracell NiMH... • Answered on Jul 12, 2009
What color should LED be when charged on duracell NIMH charger
When the batteries are charged fully the light should be green.
3/1/2009 11:25:45 PM • Duracell NiMH... • Answered on Mar 01, 2009
I want to know if my Duracell 130 Watt AC/DC Power Adapter can be used to plug in a coffee maker into my cigarette lighter? I also misplaced the User Manual to this product. Can it be replaced. I beli
It's not a good idea to run anything that needs a lot of wattage through a power converter using a 12v cigarette lighter plug. Coffee makers work by using a resistant heater element and it might work, but you could damage the coffee maker or the adapter by doing so.
3/4/2015 2:25:36 PM • Duracell... • Answered on Mar 04, 2015
Dance compitition
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYaheatman101
3/31/2011 8:36:11 AM • Duracell... • Answered on Mar 31, 2011
I have a Keb 12F5 that shows E.EF external fault. How to solve it please?
It appears to be something to do with this https://www.google.com/search?q=keb+12f5+that+shows+E.EF+external+fault 7.13.1.6 External fault With Pn.04 "Ext. fault input selection", one or more digital inputs can be programmed which can trigger the error "31: ERROR! External input" (E.EF). With Pn.03 "E.EF stopping mode" , the response of the inverter to the digital input is defined. With Pn.65/ bit 1 "2: Pn.04 = E.UP https://www.keb.su/doc/Instrukciya%20F5-A_E_H%20ver.4.0%20(ang.).pdf ..
2/27/2024 6:55:25 AM • Electronics -... • Answered on Feb 27, 2024
How do I connect my laptop to the TV?
Back in 2014 it wasn't so easy. Laptop with an HDMI port and a smart television with HDMI. ..
2/27/2024 6:47:57 AM • Electronics -... • Answered on Feb 27, 2024
2answers
I have an Emerson Quiet Kool Rooftop R/V air
I have a quiet cool roof top air conditioner and am looking for parts for it.
2/9/2024 5:25:36 AM • Electronics -... • Answered on Feb 09, 2024
Istar x 20000 USER MANUAL
Help in the link, but the one good site doesn't like my Ad Blocker! https://www.google.com/search?q=Istar+x+20000+USER+MANUAL ..
12/23/2023 11:37:12 PM • Electronics -... • Answered on Dec 23, 2023
Problem with oelmaier pac2 inverter
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjckMaPzKODAxUVj4kEHR5mBFMQFnoECBQQAQ&url=https%3A%2F%2Fforums.whirlpool.net.au%2Farchive%2F1447917&usg=AOvVaw1FGjdFQoufkwdXZJgXWdGz&opi=89978449
12/22/2023 5:44:02 PM • Electronics -... • Answered on Dec 22, 2023
Inverter problems
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwj_qqPyyKODAxWLHjQIHZRbAW8QwqsBegQIDhAG&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DZ6e4aMeAfGQ&usg=AOvVaw1gC1aMLjnqHmsV7v7EZaQm&opi=89978449
12/22/2023 5:29:39 PM • Electronics -... • Answered on Dec 22, 2023
Duracell NiMH AA/AAA Battery Charger with 4 Rechargeable AA Batteries Logo
Popular Tags
13 questions posted
Top Duracell Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Duracell Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Duracell Electronics - Others
Most Popular Question
charged duracell 2400 mah batteries 15
  • Electronics - Others
