20 Most Recent
Conair Dry 'N Straight Hair Dryer and Straightener Questions & Answers
Dryer cord is burned up where it connects to the
Hi shooby,
Yes you can repair it,just open it the dryer then trace the line of burnt wire,then you find there a fuse. Check that fuse if not open,if open replace it with a new one with same amperage and voltage. Then you can put the new replacement wire there in the terminal connection.
Regards:
VOTIT
Hair Dryer cord has electrical shortage
IF you take off about a inch of wire from the plug and re-wire it [somtimes with new plug also] make sure to remember the fuse and this should do the trick.
My iron powers on but don't get hot.
first of all check the male ac adaptor cord, maybe an open wire only cause by pulling and pushing it. if the ac cord is good then the filament may checked maybe it burn--out already
Power chord frayed and I
go to (
www.fixit.com/small apliance)
what I found out with my hair dryer (conair infinity model) was that there was a short at the plug and when I bent the wire a little to left or right the dryer would work. The plug is
GFI protected that means there is a test and reset switch built in to the plug. There for for me to fix my hair dryer I would have to replace purchase order the whole cord. The cord assembly cost almost half the price it would cost to replace the dryer with a new dryer. I purchased a new dryer.
Conair steamer GS4 reconnecting wire on switch relay
Safety First: Before attempting any repairs, ensure the steamer is unplugged from the electrical outlet to prevent electric shock.
Access the Switch Relay Area:
Remove the water tank from the steamer.
Open the casing or access panel where the switch relay is located. This may involve removing screws or clips.
Inspect the Wires:
Look for any loose or disconnected wires near the switch relay.
If you find a wire that has come off, identify its original position.
Reconnect the Wire:
Strip a small portion of the wire insulation if needed.
Reattach the wire to the appropriate terminal on the switch relay.
Ensure it is securely fastened.
Test the Steamer:
Reassemble the casing or access panel.
Plug in the steamer and turn it on.
Check if the switch relay works properly.
Secure the Casing:
Once everything is in place, secure the casing back onto the steamer.
Remember to exercise caution while handling electrical components. If you're unsure or uncomfortable with the repair, consider seeking professional assistance or contacting Conair's customer service for guidance.
CONAIR GS4 SERIES INSTRUCTIONS FOR USE Pdf Download ' ManualsLib
3/10/2024 9:04:04 PM •
Conair Irons
Answered
on Mar 10, 2024
Conair GS33 fabric steamer spews too much
Are you setting the body of the steamer on a table? If part of the hose sits lower than the steamer body steam will condense in the hose and collect in the low spot. Steam pressure will push the water out through the nozzle. If your steamer starts to sputter lift the hose so that it is completely above the level of the water reservoir and let the water drain down. Its a good idea to keep the steamer body on the floor so the hose can never get lower than it.
6/25/2021 3:12:41 AM •
Conair Irons
Answered
on Jun 25, 2021
My handheld Conair garment steamer is heating up but not producing steam. How do I fix this?
A handheld steamer uses hot steam to relax the fibers in clothing. A jet of steam is directed at the cloth suspended on a hanger. A steam wand at the end of a hose is held a short distance from the cloth - providing a smooth look without the application of scorching heat to the clothing.Steamers are ideal for soft and delicate fabrics like silk, satin, polyester and jersey. Because a garment steamer does not actually touch clothing - there is little
6/26/2018 10:10:55 AM •
Conair Irons
Answered
on Jun 26, 2018
