20 Most Recent
SanDisk 2GB Memory Stick Micro M2 Memory Card w/Memory Stick PRO Duo Memory Card Adapter Questions & Answers
Micro M2 memory card adapter
Memory stick flash memory is tricky. If it is too small, DO NOT INSERT IT. I made this mistake and was lucky enough to have some tools handy to get it back out. You'll need a different adapter to use it in the memory card reader that you have.
As for "guest" 's conundrum. You will need to use either needle nose pliers or tweezers to VERY CAREFULLY remove it. It won't be easy and you have to be careful so as not to push it farther in (which eventually it will stop going in, but still makes it that much harder to get it out)
Good luck
Nothing happens when I insert the memory card into the port, no instructions
if you are referring to a usb drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
hope it helps
Where do i insert my phone memory?
would it not of been easer to use ur usb sony ericson lead straight from comp to ur phone soon as u plug it in windows instalation wizard will automatically connect it to ur computer it normally shows in my computer file as removable file E hope this helps
How do i remove write protection from sony m2 card
click start click to open on my computer you should see your 2gb usb dcard E:or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select openRight click the icon of your 2gb usb card (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control.
hope this helps you
My phone, SE W995 can
using your phone, see if there is a file named something like "ignore my files .xyz" or similar, if so, try to delete that file and try again
I put the chip in
look at page "3/9" of this document "http://www.pqi.com.tw/upload/download/SD%20%284%29.pdf" and it will show on the lower right hand side of the picture a slot that says "write protect", move that tab towards the pins to unlock the card.BTW this is a good technical document for SD cards in general if you are interested in how they function.
I have put my m2
Check it in other computers. If it works welll then you have install driver in your system. Although now a days drivers comes automatically installed, sometimes it causes problem. Or you can go to sandisk site and get the driver.
I have a Sony Ericsson
1)disconnect the battery for 5-10 min. Then replace it &try to read card's info. OR 2)Select "restore factory settings" then try to read or 3)use a memory card reader to 1st backup info into a pc then format it by the pc.
When i connect my memory
Did you check your memory stick for viruses before opening?
Did you do opening in another computer?
Where do I put in
The adapter goes into an SD card slot. It looks like this:
http://reviews.cnet.com/sc/33248633-2-440-DT4.jpg
If you don't have a slot you will need a USB sd adapter..you can get one here:
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=usb+sd+card+reader&x=0&y=0
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
When i remove memory card and insert or switch on
Firstly switch off your mobile.Then put out your memory card adapter from your mobile.then re-enter the memory card adapter in your mobile, but sure of that if your small lock in your adapter is unlocked.It is unlocked by hand.Then ENJOY.
2gb micro 2 mermory card
SaveMyUsb.com can recover data from most damaged and faulty flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
I have a Sony digital camera with @ Scan Disk
It's no problem at all to get them back. Please see
this blog article for several free software that you can download. You'll need to use a card reader with these programs though:
All the download links listed in the article are through CNET, primarily to verify that these are malware free software, and to give you a chance to read user reviews on the software before downloading.
