20 Most Recent
Philips 42PFL7403D/F7 42-Inch 1920 x 1080p LCD HDTV Black Questions & Answers
I have a Philips 42 inch model # 42PFL7403D/F7 - trouble turning on the TV - after powering on the TV - no picture, I have to pull out the power plug a couple of times to get the picture
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
11/15/2016 3:20:37 AM •
Philips...
Answered
on Nov 15, 2016
?when I turn TV on I get a red light blinks 1 time then 2 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
brand name" to your device, in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
5/18/2016 2:48:16 AM •
Philips...
Answered
on May 18, 2016
Screen scratch
You can send it out, most any TV shop can replace it. If you have some electronic knowledge you might be able to do it yourself. Phillips is a private label for Funai. They private label A LOT, in fact you will rarely see a Funai labeled item.The reality however is you can probably purchase a new TV for the same price as repair, or even parts. Keep an eye on sites like bensbargains.net, dealspl, fat wallet and the like.You will have a NEW set, perhaps more UTD then your old one, a new warranty, perhaps more features. e.g. I purchased a new 42" Sharp from Best Buy last Summer for $350. Today it's probably even less.
12/27/2012 3:24:23 PM •
Philips...
Answered
on Dec 27, 2012
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
