20 Most Recent Rowenta Commercial Garment Steamer - White Questions & Answers
I have a Rowenta garment steamer. It will turn on but no steam comes out. Does it need to be cleaned from the build up of iron, etc. from the water? If so, how do I go about this?
Rowenta... | Answered on Jun 12, 2019
Ok. This thing is caused by scaling. If the steam generator runs out of water the sensor thinks the tank is empty and causes the machine to go to standby (basically switch off -- orange light comes on). The solution: Open the machine and clean it.
MAKE SURE THE POWER CABLE IS UNPLUGGED BEFORE ATTEMPTING TO DO THE FOLLOWING:
1. There are six screws ( phillips - you will need a long screwdriver). Two of them are hidden under the wheels (just pop off the rollers and you will see the screws)
2. Open the steam generator (there are four screws) and be very careful with the 'O' ring -- you damage it and you can say good bye to the machine. Clean it if you see scaling. The amount of scaling present would indicate how hard your water was. This itself may not be cause of the problem but now that you openend the machine, you might as well as clean it for better efficiency.
3. Disconnect the hose to the steam generator (it has two circlips) and clean it. Mine had hard deposit of scales preventing the water reaching the steam generator.
Re assemble it.
Good Luck
Alex0714
Rowenta... | Answered on Jan 14, 2019
The steam not only removes wrinkles, it freshens the fabrics - making them look cleaner. You can use this steamer on clothing, bedding and table linens and also to remove.
Rowenta... | Answered on May 08, 2018
Problem is?
Rowenta... | Answered on Feb 18, 2018
You have a build up of water In the hose. Sometimes happens because the hose is too low to the ground. Try stretching the hose up and tap it and the water should travel back down the hose.
Another reason could be that you are using too much steam for that particular fabric.
Rowenta... | Answered on Jan 05, 2018
Check this site out Terry,if not their let me know. Rowenta IS8100U1 A6 Steam Brush Parts
Rowenta... | Answered on Jul 07, 2017
take a photo (closeup ) and post it seeing it might help us help you
Rowenta... | Answered on Jun 30, 2016
Well this was helpful but also HELLfull! I guess because I have a 9050 !! I took out the screws & could not remove the hose it was attached with 2 clamps & a washer! I put the whole darn thing in my tub ( I have a sprayer in there) and yes tons of sand, black stuff and cloudy water came out. I had to do this 8 times with the hose attached! Awkward & a mess but it did finally come out clear. BTW I did it through the hose & the bottom hole. On the last run through, after my whole bathroom is soaked including me, the hose popped out! I was cracking up! turns out on the 9050 you simply push down on the ribbed hose covering and it releases. This IS NOT in the manual either. But I'm happy my steamer's like new again & live & learn ;o)
Rowenta... | Answered on Apr 15, 2016
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Rowenta... | Answered on Nov 16, 2015
Unless it smells bad I wouldn't. Just always use distilled water. The unit is boiling the water so what comes out is already disinfected.
Rowenta... | Answered on Jul 01, 2015
http://laundry.manualsonline.com/manuals/mfg/rowenta/rowenta_iron_product_list.html
Rowenta... | Answered on Apr 24, 2015
see this causes and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Rowenta... | Answered on Feb 03, 2015
Clogged unit, it's over heating. Run vinegar through it to remove deposits.
Rowenta... | Answered on Sep 08, 2014
Rowenta Commercial Garment Steamer - White Logo
238 questions posted
Popular Products
Top Rowenta Irons Experts
Ekse
Kate Henkel
Level 1 Expert
Gil Shultz
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
View Most Popular
Rowenta Irons
  • Rowenta Irons
Most Popular Question
replacement parts
  • Irons
