20 Most Recent
Saeco Talea Ring Plus Espresso Maker with Milk Island - Titanium/Silver Questions & Answers
Saeco Espresso machine - Empty drip tray (all the time)
aye that is true if you click the coffe making button directly after you have had it out you will be able to make a cup, as the machine has a 2 second response time.
Ok here is what i think:
As it registers the driptray I dont think its the sensor to it.
More i would think that its the CPU card that is not responding to that its clean.
I am sry but I have to ask this:
When it says emptie the driptray are you actually taking out the container that is located under the brewing unit, and not the "drip tray" were you put the coffe mugs?
Also when i think i have a sensor problem I allways take out everything. Brewing unit, dripwater container, dregbox, and the watercontainer. and have it out for atleast 2 minutes ( clean it under the mean time) and put it back again.
As I dont have the machine infront of me i cant be certain:)
The selction ring on the Talea Ring Plus doesn't work anymore
I had the same problem, after dismantling the machine I found that the touch detector is glued to the back of the plastic front panel and had become detached, so that it was too far from the operator's finger to work. Reattached with fresh glue, checked connection to main board, works perfectly now.
Saeco talea ring coffee machine reurning error code
Code error 1 on talea modes means that your grinder is blocked and grinder sensor is not reading properly.
Are you using oily beans? If you are using oily beans the oils may be blocking the grinder and giving the code 1, and you should try to switch to non oily beans before getting it serviced.
We are authorized Saeco Talea repair center based out of New York. You can if our contact info at
www.CeriniCoffee.com.
If you need a service center near you visit
www.SaecoOutlet.com.
Out of service 5 saeco
code 05
No flowmetre pulses when the pump is activated
flowmetre defective
Pump defective
Lead shifted
