Hello Jim, thanks for your post!
From my understanding your Frigidaire range, LFGF3014LBC, is displaying an error code of "F31". The "F31" error code stands for a shorted probe connection which could be an issue with your EOC (Electronic Oven Control), wiring harness, or RTD (Resistance Temperature Detector). I would suggest performing a reset on your range to help clear out any false error codes. You can reset your range by flipping off the household circuit breaker for ten minutes. I hope this information is helpful to some degree. -Matt
Good Morning friend, thank you for your inquiry!
From what you have described your Frigidaire range is displaying an "F31" error code. An "F31" stands for a shorted probe connection. This could be an issue with your RTD (Resistance Temperature Detector), EOC (Electronic Oven Control), or wiring harness. I would recommend performing a reset on your range to help clear out any false error codes. In order to reset your range you need to disconnect power from it for roughly ten minutes. If this does not help resolve your issue and you continue to receive the error code you may need to have a professional out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Thank you for your post, friend!
I would suggest either your switch or element could be causing the problem within your burners. I would perform a reset on your appliance which you can do by unplugging your power cord or flipping the household circuit breaker for ten minutes.
If that does not help correct the issue I would recommend reaching out to a professional for proper diagnosis and repair of your range. I hope this is helpful. -Matt
Hello friend, thank you for your post!
I understand that you need to fix a sprung oven door on your Frigidaire range. If you need to replace the hinges or door we recommend seeking assistance from a professional. Some of these intricate parts do require precision and patience, therefore when replacing the exchange of such components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Matt
194 questions posted
353 Questions
213 Questions
158 Questions
110 Questions
92 Questions
