20 Most Recent Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Questions & Answers
How old is ED22DQ
20 yrs old
11/25/2022 11:38:36 PM • Whirlpool 25.3... • Answered on Nov 25, 2022
0answers
Half to push ice despenser sevarle times and hard to dispens ice is there a switch in side the door that activates the ice dispenser model#ED5VHEXVQ01
The lever is pretty much the switch, in a sense. Actually it acts as a "middle man/agent", as the actual "switch" should be located just behind the lever inside the door. Logically, the only reason that I can give as to why you are having this issue is due to forced wear and tear on the internal switch itself, commonly caused by people forcing the lever backward to trigger the "switch" in the act of getting ice. The node/knob on the internal switch could be depressed to the point that it will not pop back out as it normally should, or the harness/housing that it is inside of may possibly be worn if not broken to the point to where when the lever is engaged it moves the internal switch backwards until it stops against the backing of the inside of the door, making it hard if not sometimes impossible for the lever to full engage the "switch" in order to get a full flow of electricity through the wiring. One last theory is that through normal wear and tear, the wiring could be bad, be it due to shortage or moisture buildup inside the door of the fridge.
11/16/2012 1:39:56 AM • Whirlpool 25.3... • Answered on Nov 16, 2012
Whirlpool ed25rf can I remove water filter?
You CAN just bypass the filtration system, BUT, you're going to have mineral deposits buildup in various locations over time. If that's not a problem for you, then TAKE OFF OSMOSIS SYSTEM, and just extend the hose that goes into the filtration system---- to the hose that exits the system, connect the two, and that's it, all set. Make sure all your hose connections are secure, so you don't get leaks, or flood your floor. You could put in an activated charcoal sytem, which will take out chlorine, other chemical contaminants and give much more water per minute than a RO system, if that's your reason for wanting to remove it. You could easily use your existing RO unit, merely remove the RO membrane filter, and bypass it, and that would use all the other filters it has, without slowing the water flow excessively. Also, it will, NOT take out any minerals, or heavy metals or viruses, like the RO membrane will do, but the water flavor is more how most people like.
9/24/2012 4:27:20 PM • Whirlpool 25.3... • Answered on Sep 24, 2012
Fridge is not cooling
Hereis a link to schedule a service call: http://bit.ly/yLv4Z5 . I hope this information is helpful. Sincerely, Melaine, Whirlpool Socail Media.
7/10/2012 3:26:38 PM • Whirlpool 25.3... • Answered on Jul 10, 2012
ED0GTQXMQ00 water dispenser
Hi. We are sorry that the ice maker is not working. Hereis a link to schedule a service call: http://bit.ly/yLv4Z5 . I hope this information is helpful. Sincerely, Melaine, Whirlpool Socail Media.
7/10/2012 3:24:19 PM • Whirlpool 25.3... • Answered on Jul 10, 2012
Need to change water filter
Hi Mr. Callaway. I understand you need to change the filer in your refrigerator. Here is a list of YouTube videos we offer to help you:http://www.youtube.com/user/whirlpoolcorpcare#p/c/724AE2877520B916/0/lTVfbVkEINIReplacingrefrigerator grilleb>http://www.youtube.com/user/whirlpoolcorpcare#p/c/724AE2877520B916/1/C_RBfawcyJ4Replacing interiorSide by Side(upper right) water filterb>http://www.youtube.com/user/whirlpoolcorpcare#p/c/724AE2877520B916/2/Cj6QRMrEXmUReplacingFrench-door/Bottom Mount refrigerator filter b>http://www.youtube.com/user/whirlpoolcorpcare#p/c/724AE2877520B916/3/CPZgNYxFjjsReplacingIn-Grille Filtersb>http://www.youtube.com/user/whirlpoolcorpcare#p/c/724AE2877520B916/4/D2W8jNl5PYsPurging waterlines I hope this information is helpful. Sincerely, Melaine, Whirlpool Socail Media.
7/10/2012 3:19:54 PM • Whirlpool 25.3... • Answered on Jul 10, 2012
Refrigerator wiring diagrams
Hi Mr. Ashton. We understand you need a wiring diagram for your unit. We do not have those online, be we can email them to you. Please call Whirlpool at 866-698-2538 with your full model, serial number, and email address handy, so we can email you the diagram. I hope this information is helpful. Sincerely, Melaine, Whirlpool Socail Media.
7/10/2012 3:17:46 PM • Whirlpool 25.3... • Answered on Jul 10, 2012
Door frame warm
Nearly all modern fridges are self defrosting. Additionally, some models offer the option to minimize moisture on the cabinet. To do both the defrosting and controlling moisture build up, small heaters are used. Defrost heaters are located in the freezer compartment.Typically, the other heaters are installed in the frame on the front of the fridge cabinet, near the freezer opening. This is where sub-freezing cold air would escape and contact the warmer (room temperature) outer cabinet. This causes condensation much the same way a glass of cold water "sweats" sitting on a counter or table. The warmer and more humid the room is, the more quickly the condensation will form. The heater is used to quickly evaporate any moisture that collects on the cabinet. This heater is operated at the same time as the defrost heater, and they are turned on by a timer, 2 or 3 times a day for about 20 to 30 minutes each time. When they are powered, it is expected that the cabinet will be warm to the touch. You may smell plastic, as the door seals adjacent to and in contact with the heated parts of the freezer opening are warmed, and is normal - particularly if new. The heaters should never be hot to the touch nor should smoke be seen.I hope this helps!
2/14/2012 10:05:20 PM • Whirlpool 25.3... • Answered on Feb 14, 2012
The front door of my side by sde refrigerator is rusting
Go to www.applianceart.com -- These guys specialize in refacing your appliances. Their motto is Don't replace your existing working appliances -- Reface them. They offer magnetic and vinyl options that will fit over the existing surface. I believe the vinyl option will work best for you.They have solid colors, designs, textures and even stainless steel options.Worth checking out.12_9_2011_4_50_04_pm.jpg
12/9/2011 4:50:35 PM • Whirlpool 25.3... • Answered on Dec 09, 2011
Blows warm air , quit working n keeping food cold
Yes if what your experiencing is that ya hear the compresser click on and off several times the relay is going to be the problem...its a pretty common thing and happens to a lot of refrigerators,
10/12/2011 6:03:45 PM • Whirlpool 25.3... • Answered on Oct 12, 2011
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
191 questions posted
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
half push ice despenser sevarle times
  • Refrigerators
