20 Most Recent
Tomtom ONE XL-S GPS Questions & Answers
Need to update Thailand map for finedrive
You can get the latest version of the map from the tomtom.com website . Select MAPS ... and choose THAILAND (from the AUSTRALIA, NEW ZEALAND & Asia group of maps).
It's easier to buy a map than trying to update an old version
KELT.MCFADDEN@I UPDATED MY DEVICE AND
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
The green power light on
First you need to check if the battery is okay, try it on another tom tom gps receiver, if it is working and the screen wont turn on, then it means there is a hardware problem, probably the flexi ribbon that is connected to the screen is either loose or bad, this will require you to disassemble the tom tom and check for the flexi ribbon that connects to the screen, then you resit it or change the ribbon, that should do the job.
You can also try to reset the tom tom first before disassembling it. By pressing and holding the power on/off button for about 15 seconds, if that does not do the job, then you can go ahead and disassemble the tom tom.
Hope this solution helped
Tried to install the free map update/upgrade(North
There is this problem with TomTom. Tom do not seem to overwrite the existing map file. So before trying to install the map, you need to delete the folder containing map.
Once you have connected your TomTom to the computer, close the TomTom home window. Double click on my computer. You will see the TomTom hard drive as a drive (like you see the CD drive) double click on that . Once the folders of the TomTom hard drive opens, look for a folder named USA_Canada_and_Mexico_P. Right click on it. click properties. Check whether the size of this folder is approximately around 1.3 GB to 1.5 GB. This is just to make sure we have the correct folder. After confirming this is the map folder, copy this folder to your computer for back up purpose. Once you have it safely in your computer, delete this folder from the TomTom hardrive. Go back to TomTom home software. Use the map guarantee to update/Upgrade the new map. You will see this time around the installation completes without a problem.
Wrong final location
The GPS technology was created for military purposes. Its civilian use has limitations such as no pinpoint accuracy. Also maps are being update all the time.
French language
There should be a menu on your gps, and it should be a lang. settings on there. Under that menu than you can change it back to english.
Set time
Go through the menu and you will see options for time or clock. It is probably set on 24 hr clock and this is why it is 12 hours out. If you have a choice of 12 or 24 then choose 12. If you have to use 24 hr ensure that you reset the time as 1300 hrs for 1pm,1400 hrs for 2pm etx.It will be shown as "time format"
My Tomtom One XL, shows strange language and I can t change it.
Boot up your tt, tap the map screen, then tap change preferences (bottom far right icon next to the forward arrow), tap the forward arrow until you come to an icon with flags, tap the flags icon. You will then be able to set your language.
Hope this helps
1 Solution for
No problem, my mistake , so sorry.
Keep you in mind Sincerely phillip smit
