20 Most Recent Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Questions & Answers
Whirlpool duet electric dryer taking too long to dry
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent  doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket  thermometer can be used for this. It should cycle between 120 degrees and 170 degrees. Check that the drum seals to make sure the are not worn out.
4/15/2023 9:53:53 PM • Whirlpool Duet... • Answered on Apr 15, 2023
2answers
Whirlpool duet dryer says control locked what do i
Hi
Press and Hold the End of Cycle Signal Button for 15 seconds, this will unlock the control lock of your Whirlpool Duet. Hope this helps...please post back for further assistance.
Daniel
12/1/2018 11:56:25 AM • Whirlpool Duet... • Answered on Dec 01, 2018
I have a Whirlpool Duet Dryer that is locked on the heavy duty cycle, I cant switch to another setting, it wont cancel out. I've tried unplugging it for some time to reset it. It is still stuck o
when you unplug it you're resetting the computer board just like your house computer does,so if it helped by unplugging it i would have to say the board is bad and needs to be replaced.next time send the model number off of the machine
2/2/2018 5:15:03 PM • Whirlpool Duet... • Answered on Feb 02, 2018
How to replace blower belt on whirlpool cabrio dryer model wed7800xw0
first put pulley onto blower fan housing i think you have to counter clock turn to put the pulley by hand. put you one hand inside the blower housing and hold the fan then use pliers and tight the pulley. now put belt on motor pulley first then put belt on blower's pulley it is hart to put on so little belt on pulley and use other hand and turn fan from inside so blower's pulley turn and belt get to pulley. last tight the pulley again. turn fan by hand to make sure belt run ok. hope it will help you.
5/4/2017 2:05:33 AM • Whirlpool Duet... • Answered on May 04, 2017
2answers
Control lock message
press the "lock" button for like 5 full seconds and see if goes out
12/1/2016 12:28:29 PM • Whirlpool Duet... • Answered on Dec 01, 2016
I CHANGED DRUM SUPPORT ROLLERS AND PUT BACK TOGETHER AN IT WILL NOT START
Suggest the following.
  • Check drum light. No light defective door switch. Light yes one leg of 220 circuit OK.
  • Be very sure motor doesn't start when you set to run. Belt may be off the motor and motor is very quite. Fix belt. Motor may be stuck or failed listen to hear if it is buzzing
  • When pressing start button listen for distinctive run relay activation. If when the start button is depressed I would expect to here the relay.
  • Motor run circuit relatively simple. The drum motor and blower are one assembly.
11/30/2015 9:53:38 PM • Whirlpool Duet... • Answered on Nov 30, 2015
Change drum support rollers and put back together and will not start
Check the door interlock switch. You should be able to hear it click as you open and close the door. It is easy for it to snap out of place on some models. You can operate it by hand to check the action. Hope this will help
11/28/2015 10:19:26 PM • Whirlpool Duet... • Answered on Nov 28, 2015
Are there a reset button on the motor
no, but there is a thermal fuse, normally located on the blower duct, near the blower wheel. More than likely, that's the issue if it doesn't start.
11/28/2015 8:20:04 PM • Whirlpool Duet... • Answered on Nov 28, 2015
Are there reset button on the motor
Whirlpool duet sport F21 error code fix - YouTube
? 4:39 https://www.youtube.com/watch?v=qQTvBSnEWsI Feb 22, 2010 - Uploaded by heli400 Also note TROUBLE SHOOTING MANUAL IS TAPED TO THE ...I have replace 6 detergent ben hose 1 motor the membrane on thebuttons .... I've owned the washer for 6 years and I never knewthere was a filter underneath!
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...
? 7:29 https://www.youtube.com/watch?v=SPRqKVE8JfY Oct 21, 2011 - Uploaded by canyonman1963 I have a Whirlpool Duet MOD GEW9250PWI It's not making any noise, ... only" I've unplugged it and plugged it back hoping it would reset it. ... The service man I use stated it was the motorgoing bad, the smell of ... i checked the door switch, it was fine too i believe. so thermal fuse ... There still is not start up.
11/28/2015 7:33:01 PM • Whirlpool Duet... • Answered on Nov 28, 2015
Change dryer cord from 4 prong to 3 prong
If you have a similar conectio as mine, you can't
11/6/2015 4:03:30 PM • Whirlpool Duet... • Answered on Nov 06, 2015
How do I get into my whirlpool duet front loader dryer to clean the lint out
Hello. First, turn the power off to the dryer or remove the power cord from the AC outlet. Next, locate the 2 screws in-between the upper and lower front panels and at the bottom front of the dryer--there will be 2-3 screws, usually 1/4 inch hex head, and remove them--use a magnetic nut driver, it makes it a whole lot easier! (note:sometimes, to replace the panel, you have to push up on the bottom of the panel hard to get the screw holes to line up again.) Set the panel aside. Open the dryer door and remove the lint screen from the holder. Close the door. Next, notice the blower housing cover, pic 3, #45, lower left corner. There should be 3-4 screws holding the cover to the blower housing. Remove the screws and cover--use caution--most metal edges inside a dryer are unfinished and razor sharp--akin to putting your hand inside a box of razor blades(ask me how I know this, lol). Remove any lint build-up inside the cover with a vacuum. Again, using a vacuum, suck out any lint from inside the blower housing and fan as best you can. Take care to not damage the fan blades! Now, try to remove as much lint build-up as you can with the vacuum. Be especially careful when vacuuming around the mouth of the heater element. Do the best you can. At this point, re-assemble the dryer using the reverse of assembly. If there is still a lot of lint inside the cabinet and you can't reach it--STOP! In order to remove the remaining lint requires removal of the front bulkhead(large metal plate that supports the front of the drum), drum belt, and drum from the cabinet. This is INVOLVED and can be very difficult to re-assemble if you have never done it before. Call for service. I hope I helped you! 25889250-j24yshksbwd4fbvc2jhjnsvg-5-0.jpg 25889250-j24yshksbwd4fbvc2jhjnsvg-5-1.jpg 25889250-j24yshksbwd4fbvc2jhjnsvg-5-3.jpg
10/3/2015 9:57:34 PM • Whirlpool Duet... • Answered on Oct 03, 2015
Help took control plugs out and didnt get clear pic of where one wire plug belongs need a schematic
Bottom panel. But you shouldn't be able to put harness connector in the wrong terminal. The normally all have their own special cut in the board or they will be color coded.
8/1/2015 5:17:20 PM • Whirlpool Duet... • Answered on Aug 01, 2015
My dryer is stuck in manual mode. You can't get it to change to an of the automatic modes. It will only change between the three manual modes
Sounds like a main control issue. I would call a service technician for further investigation. Try shutting the breaker off for 10 minutes or so and see if this corrects the issue.
8/1/2015 5:07:22 PM • Whirlpool Duet... • Answered on Aug 01, 2015
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
414 questions posted
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
changed drum support rollers put back
  • Dryers
