20 Most Recent PNY Optima High-Speed 512MB Secure Digital Memory Card Questions & Answers
Maybe u can change ur ram or u can reinstall your system its better to install windows 7 64 Bit
Thanks
PNY Optima... | Answered on Jan 17, 2018
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
PNY Optima... | Answered on Feb 08, 2010
Try to use your card in a clean computer and run a virus or malware test on it. Make sure that the card has no unwanted hidden folders that may contain virus files unblocking the card from being accessed by your printer.
PNY Optima... | Answered on Dec 29, 2009
Did you format it to FAT32 before you placed music on the card?
PNY Electronics... | Answered on Jan 16, 2019
The flash drive may need to be REFORMATTED. In some cases, the flash drive is pulled out from the USB port incorrectly. That can lead to a damaged Flash Drive.
Always remove Flash Drives by using the EJECT method.
To format the USB Flash drive, go to the File Explorer (the bottom row of Icons on the computer screen showing a manila folder inside a holder) and locate the USB drive by letter, such as drive B,C,D, etc. One of these letters or higher. Tap the corresponding to the USB drive and an option box comes up. Select "Format" (Quick is ok). Once formatted, the drive is ready to accept data once again. If it cannot be formatted, then the USB DRIVE may have sustained damage to the circuit and no longer can be of service.
PNY Electronics... | Answered on Feb 05, 2018
Google cloud.
PNY Electronics... | Answered on Oct 17, 2017
hi buy a card reader cost about $5 dollars on E/BAY plug it into youre mac & put the sd card in & hope it all works ...cheers..
PNY Electronics... | Answered on Apr 06, 2017
The Elite X has faster read/write speeds (and is more expensive). Otherwise there is no functional difference.
Turbo Attache 4 specifications
https://www.pny.com/turbo-attache-4-usb-flash-drive-black
Elite X specifications:
https://www.pny.com/elite-x-usb-3-flash-drive?sku=P-FD256EX-GE
PNY Electronics... | Answered on Apr 02, 2017
Make sure nobody put hidden files on the Flash,
Copy the files off, then reformat the flash in NTFS unless you have an old computer.
FAT32 will work, the limit is 4GB for a single file and 2TB for the whole drive. If it was an SD or variation I would have kept with this for compatibility with cameras ect. NTFS for a USB has a couple features that make it slightly more reliable and faster for a situation where you have many small files.
Below is a link to a simple flash formatting tool.
HP USB Disk Storage Format Tool
PNY Electronics... | Answered on Jul 31, 2016
no it cannot work
Dell N5010 is a DDR3 memory
Correct spec speed is
DDR3-1066/PC3-8500
PNY Electronics... | Answered on Oct 20, 2015
You have to format the drive to the correct type before transferring your music onto it. Not sure whether you're using windows or Mac. In windows go into file explorer, right click the usb drive and select format. This will show you a section of formats including FAT32.
PNY Electronics... | Answered on Mar 01, 2015
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
PNY Electronics... | Answered on Dec 02, 2014
The card has a sliding switch on it. Slide to the opposite position and you should be OK.
PNY Electronics... | Answered on Oct 03, 2014
You don't really close it, you just tell the computer to turn it off so you can safely remove it, thats what the "Safely remove drive" option on windows does. Go to it and select the drive you want to remove, it will do the rest.
PNY Electronics... | Answered on Aug 17, 2014
Consider downloading a manual for you model for the answer.
what type was in it before? IT wil require the same type but it has space limitations.
www8.hp.com/us/en/home.html
PNY Electronics... | Answered on Jul 06, 2014
PNY Optima High-Speed 512MB Secure Digital Memory Card Logo
Popular Tags
5 questions posted
Top PNY Electronics - Others Experts
Marvin
Marvin
Ekse
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • PNY Electronics - Others
Most Popular Question
format sdhc
  • Electronics - Others
