20 Most Recent
Maytag Gemini 30" Self-Cleaning Freestanding Electric Double Oven Range - Stainless-Steel Questions & Answers
I have a Maytag Gemini Double Oven Range. The
turn off breaker or unplug. then wires commonly burn out near the heating element. To determine if a wire has burned out, inspect the wires leading to the element. If a wire is burned out, it will often be visibly burnt.
Oven will not heat past 195 degrees
Check and see if you have blown a fuse which is usually in the top of the stove in the area of the clock if you have one. You usually can get in from the back of the stove at the top.
Maytag Stuck on "Delay"
You are in the Tiller and Cultivator section of FIXYA but have you tried unplugging or shutting off the Breaker for a few seconds and let the Oven 'reboot'? Ahh, what ever happened to the simple good old fashioned Ovens?
