20 Most Recent Denon AVR-1513 Questions & Answers
My unit is not powering ON
Short circuited component/s inside the circuit board.
10/25/2015 7:17:02 AM • Denon AVR-1513 • Answered on Oct 25, 2015
Is there a general issue with video and sound cutting/jumping out with more volume applied?
Power supply section circuit problem. Check all the voltages and filter capacitors at this section. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
6/2/2015 12:15:56 PM • Denon AVR-1513 • Answered on Jun 02, 2015
How do I unlock Denon AVR-1513 Remote
8/10/2014 1:43:58 PM • Denon AVR-1513 • Answered on Aug 10, 2014
Volume coming from tv is so low
you have to goto setting and set the speaker to tv if you have a newer tv
3/28/2014 9:57:28 PM • Denon AVR-1513 • Answered on Mar 28, 2014
0answers
0answers
0answers
Blinking red light
How many times this power/standby light blinks? It is fault indication, and are fault codes. If you wish to get some details about these codes, try this link. http://electronicshelponline.blogspot.com
12/23/2013 6:05:21 AM • Denon AVR-1513 • Answered on Dec 23, 2013
0answers
No sound coming out of the speakers
set the speaker as default, whichever you are testing, it will start working, just right click and select.
12/15/2013 7:33:52 PM • Denon AVR-1513 • Answered on Dec 15, 2013
Stereo shuts off at 69
This could be due to the systems overload protection kicking in, which under normal circumstances shouldn't happen, I suggest moving the speakers next to the amplifier and if possible use anew piece of wire to test the speakers start with one and test each individually. I think you possibly have a small short in one of the wires. Or one speaker is damaged. Measure the resistance between each speaker wire pairs. The speaker will probably be either 4 or 8 ohms check that this is the case. Read the speaker labels for clues. Were they the original speakers supplied? by the same manufacturer?
12/9/2013 2:01:11 AM • Denon AVR-1513 • Answered on Dec 09, 2013
I got a LG ht33s subwoofer to my denon avr1513. Connected with RCA cable but no sound.
make sure the wattage of the amplifier has the same amount or more wattage to the subwoofer otherwise it will not be able to produce sound because of power complications
12/7/2013 8:17:05 PM • Denon AVR-1513 • Answered on Dec 07, 2013
Every time I turn power off or change input source
Check and replace its main system control memory IC.
8/23/2013 11:31:33 AM • Denon AVR-1513 • Answered on Aug 23, 2013
Avr 1513 no signal to subwoofer
Check its speaker connections. Check the speaker using a dry cell. If it is found OK, check the sound settings. If you wish to get more details, check this link.
3/22/2013 10:25:12 AM • Denon AVR-1513 • Answered on Mar 22, 2013
Denon X6700h has no power at all.
If there is a fuse, it will be on the power board, easy to spot, a glass cased fuse, or a small white ceramic fuse. Normally though, a 125,000 volts wrecks everything connected to power. https://www.google.com/search?q=Denon+X6700h+has+no+power ..
8/18/2023 6:18:18 PM • Denon Televison... • Answered on Aug 18, 2023
2answers
Denon 687 ,,,,red light is on then I push the power button and it blinks green and their stays green but no display at all nothing else lights up
Considering you have a standby light we know the hot side of the power board is working, next step is test the power on signal coming from the main board, it should be marked on the legend on the power board what pin is power on, will be marked PO_ ON PWR or something like that, you need at least 3 vdc there when you turn the set on, if it's missing replace the main board, if you see voltage replace the power board, easy simple fix with only one measurement, verses guessing what board is bad. Sorry you didn't get any other useful help, there are some posters on here giving non helpful generic help anyone would know to try
3/24/2023 12:56:49 PM • Denon Televison... • Answered on Mar 24, 2023
Denon AVR-1513 Logo
Popular Tags
24 questions posted
Top Denon Televison & Video Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Denon Televison & Video
Most Popular Question
unit not powering
  • Televison & Video
