20 Most Recent Bose RC-25A Remote Control for Lifestyle 25 & 30 Questions & Answers
Where is the Bose 25 infrared sensor on the
hellllllo..........RC 25 is not infrared red its radio frequency.........tkx......g.scott
10/12/2014 2:08:21 AM • Bose RC-25A... • Answered on Oct 12, 2014
Bose remote RC-25 won't work anymore
Check the remote control for its infrared emission. Check it with fresh batteries. Check it battery contacts, inside its battery compartment for any rust or dust accumulated, which prevents the electrical contacts. If all are found OK, you remote control need cleaning. To clean it, you have to open it. If you wish to know more details about how to clean and check a remote control, check this link.
2/17/2013 3:58:10 PM • Bose RC-25A... • Answered on Feb 17, 2013
Bose solo won't turn on. Unplug to reset works but takes countless retries. Tries several outlets with same results. One it turns on it works, until turned off or auto off for a few minutes.
I have the Bose Solo 10 and it did the same as yours. I did all of the suggested fixes and nothing worked. I changed out the IR sensor and it worked for a while and it went out again.I'm an electronic engineer so I unplugged it and did the reset and got the acknowledgement tone. That told me the the units power supply and electronics was good because it does a self check when you reset it. I took the IR board and did a bench test on it. The board worked on the bench. When I put it back in I checked the voltage on pin 7 of the IR sensor, no voltage. I checked the voltage on the main PCB and I had 3.2volts. Checked the ribbon connector and the voltage was getting to the connector on the IR board but it had a bad connection from the ribbon to the board. I put a jumper from the ribbon to the IR board and it's been working all day with no problem. I checked and a lot of people are having the same problem the we experienced. Bose should have a recall on the connector on the IR board because you cannot turn this unit on manually. When you have this problem you can't do anything with this unit because it is too big for a paper weight. The next best thing to do is replace the IR board because I could not find the proper connector that's on the IR board.
10/15/2023 4:41:56 PM • Bose Televison &... • Answered on Oct 15, 2023
Bose Acoustimass 10 basic connection issue on board?
If there are just two wires on the transformer secondary, they are interchangeable. Just to make sure, look on the transformer for markings identifying the wires. If the wires are the same color, have the same terminal connectors (probably so; you said the plug goes on ether way), and the same ID marking on the transformer, they definitely are interchangeable. You could check the end of the plug to see which side has the holes for the pins, then match that to the base of the pin connector on the board if it has a base instead of just two bare pins sticking up. I'm sure somebody's already told you "after the horse is gone" that you should have taken a picture before disassembly, but that doesn't help now. : )
9/3/2023 3:32:57 PM • Bose Televison &... • Answered on Sep 03, 2023
TOUCH SCREEN remote for Bose Lifestyle 50
For remote, probably better to send it to Bose or even try a warranty repair under their 1 - 5 year scheme. Or, they will tell you the authorised repairer.
Repair and Replacement
Bose https://www.bose.com > service_and_repair_request Find your serial number. Each Bose product has a unique serial number or 4-digit code located on the product or original packaging. Most serial numbers can ...
Lifestyle® 50 system - Bose Product Support
Bose https://www.bose.ca > bose_home_theater_support > b... Discover product support for your Lifestyle® 50 system. Learn how to operate your product through helpful tips, technical support information and product ...
4/9/2023 7:06:31 PM • Bose Televison &... • Answered on Apr 09, 2023
Bose v35 Sound plays but no picture.
If you have already tried using different HDMI cables and testing the system on different TVs with no success, here are some additional troubleshooting steps you can try: Check the input settings on your TV: Make sure you have selected the correct input on your TV. Sometimes, the input setting may have changed accidentally, or the TV may have multiple HDMI inputs, so it is worth double-checking. Check the output settings on your Bose V35: Make sure the output settings on your Bose V35 are correct. Go to the "Video" settings on your Bose V35 and make sure the "HDMI Out" is selected as the output option. Power cycle your equipment: Try turning off your TV, Bose V35, and any other devices connected to the system. Unplug everything from the power source, wait a few minutes, and then plug everything back in and turn it on again. Reset your Bose V35: If none of the above steps work, you can try resetting your Bose V35 to its default settings. To do this, turn off your Bose V35 and unplug it from the power source. Then, press and hold the "Source" and "Setup" buttons on your Bose V35 remote control for about 10 seconds until you see "Resetting System" on the display. If you have tried all of these steps and are still not able to get a picture, it may be a hardware issue and you should consider contacting Bose customer support or a professional repair service for further assistance.
3/19/2023 2:57:33 PM • Bose Televison &... • Answered on Mar 19, 2023
Remote control for Bose Wave Radio
Based on the serial number you provided, the manufacture date of your radio is indeed the 263rd day of 2001, which is September 20, 2001. Regarding the remote control, the AWR-1G4 model does not come with a remote control as it was designed to be a simple, easy-to-use radio without any advanced features like remote control. However, there are aftermarket remote controls available that are compatible with this model. It is not necessary to find a remote control with a model number ending in 1G4, as the remote control may have a different model number or may be a universal remote control that is compatible with multiple models. You can search for a remote control that is compatible with the AWR-1G4 by looking for one that works with the same brand (in this case, the brand is likely to be "Acoustic Research") and has similar features. Keep in mind that not all aftermarket remote controls may work perfectly with your radio, so it's best to read reviews and make sure the remote control you choose is well-reviewed and reliable.
2/26/2023 7:00:06 AM • Bose Televison &... • Answered on Feb 26, 2023
2answers
Mute not working on sound bar remote
Hi, Please double check that you've restarted all devices involved and then repeat this again. Also, please make sure that the volume buttons aren't stuck in the down position. Also, please make sure that soundbar isn't blocking tv sensor. You might need to re-setup your bose soundbar. Thank you.
10/12/2022 4:06:26 PM • Bose Televison &... • Answered on Oct 12, 2022
Bose cinemate SR 1 accoustimas module . No power.
Open up your Accoustimass module. Find and replace the internal fuse.
5/7/2022 6:59:22 PM • Bose Televison &... • Answered on May 07, 2022
2answers
Can you turn on a bose solo tv system without the remote
Yes-turn off tv power & bose power---then bac on
11/29/2021 6:38:33 PM • Bose Televison &... • Answered on Nov 29, 2021
I need the Bose Soundtouch 300 service manual.
https://www.eserviceinfo.com/index.php?what=search2&searchstring=bose+300300 visit this site to download its service manual. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
8/25/2021 1:02:30 PM • Bose Televison &... • Answered on Aug 25, 2021
Necesito el diagrama de servicio de Bose soundtouch 300.
English please
8/20/2021 11:51:04 PM • Bose Televison &... • Answered on Aug 20, 2021
Linking a Bose sound bar to a Century Link Prism remote
Your Century Link Prism remote control may not contain the Bose sound bar codes.
11/8/2020 1:20:44 AM • Bose Televison &... • Answered on Nov 08, 2020
My bose solo 5 tv sound system has stopped functionning. What is my problem and how do I fix it?
SALUDOS TRATA DE RESETEARLO SI NO LO LOGRAS POR Q NO POSEE RE-SET LO MAS PROBABLE ES QUE TENGAS UN PROBLEMA CON LA FUENTE DE ALIMENTACI?N DEL MISMO TRATA DE ESPECIFICAR MAS EL PROBLEMA PARA PODER AYUDARTE MEJOR
10/11/2019 6:18:21 PM • Bose Televison &... • Answered on Oct 11, 2019
I have bought a bose solo 5 sound bar and need a code for the remote to conect my zgemma box please can you help
Oooops little late however utube step by step
4/14/2019 10:08:21 AM • Bose Televison &... • Answered on Apr 14, 2019
Hi, I try to fix a BOSE AWR1-2W. It is light up, but there is no audio. On the opamps there is -8V, but there is no positive voltage. I've been reading the answers, but there is no Q4 transistor in it. I can find +21V and -21V as well, but I can't find that where is the positive voltage disapear. Has anyone any idea about the power supply? I can't find any zener or voltage regulator for the OPAs. Cheers Pete
I am not an expert in such things but taking a flying guess and offering some sensible (I think) advice. You shouldn't attempt to repair such an item without a service sheet or service manual and suitable test equipment. I suspect the power supply or part of the supply could be switch-mode or inverter type requiring an oscilloscope for testing. The radio is as much computer as it is radio and will undoubtedly contain sensitive CMOS circuits that are easily damaged and random prodding with test leads definitely isn't wise. You have a premium piece of gear there, probably one of the most expensive radio alarm clocks on the market that few ordinary folk would buy. It would be best to entrust repairs to an approved dealer or to enquire if Bose have a fixed price exchange scheme...
10/24/2018 9:28:20 PM • Bose Televison &... • Answered on Oct 24, 2018
Bose RC-25A Remote Control for Lifestyle 25 & 30 Logo
Popular Tags
3 questions posted
Top Bose Televison & Video Experts
Paul Bade
john h
Are you a Bose Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Bose Televison & Video
Most Popular Question
bose 25 infrared sensor
  • Televison & Video
