20 Most Recent
Apex Digital APEX K12B-C2 Remote Control Questions & Answers
Apex k12b c2
If only one button do not work, it might be set right by cleaning it. But to clean it, you must open the remote control If you check the link given below, you can get the procedure about how to clean , repair and check a remote control
http://electronicshelponline.blogspot.com/ Pull up older posts there.
I need to know how to change modes without controller when I'm using a dvd
Without a remote controller, you may have limited options to change modes on your Apex digital TV. However, you may be able to change the mode by using the buttons on the TV itself.
Here are some general steps you can try:
- Turn on your TV and make sure your DVD player is connected to it.
- Look for the "Menu" button on the TV and press it.
- Navigate through the menu options using the arrow buttons on the TV until you find "Input" or "Source."
- Press the "Enter" button to select the input/source option.
- Use the arrow buttons to select the input/source that corresponds to your DVD player.
- Press the "Enter" button to confirm the selection.
- Press the "Menu" button to exit the menu.
Note that the specific steps may vary depending on the model of your Apex TV. You may also consult the user manual for your TV for more information on changing modes without a remote controller.
