20 Most Recent
2001 Chevrolet Suburban 1500 Chassis Brain Box Questions & Answers
2001 suburban brain replacement
Some are under the hood and others are in the kick panel on passenger side. your is most likely under the hood. You will need to remove the PCM from your old and place in your new brain module. It has to be the same number and attach the same, and memory flash to match your vehicles options
2001 chevy suburban fuel tank pressure build up.
Your problem is very simple, it's your fuel sending unit mounted inside the tank. Here is the procedure test you need to prove it. First you know that your gauge is working so there is no need to prove that, now drop the fuel tank and with extra care remove the fuel sending unit, with the wiring hook up at the sending still, raise the floating ball up and down at the same time watch your gauge move up and down if, the gauge reads the same as it was on the vehicle you know that the fuel sending is defective replace it. Reverse procedure on reinstall the new one. Good luck
CRANKING BUT NOT STARTING
Have you checked to be sure that you have spark & fuel? After you figure that out then you know where to go.
How to reset automatic sliding door on chevy venture van
The rear side door actuator control modules monitor the power sliding door positions at all times. Whenever the battery positive voltage supply to a rear side door actuator control module has been removed or the on-board diagnostics have been activated the power sliding door system(s) must be re-initialized. Re-initialize the right or left power sliding door systems using the following steps:
- Turn the ON/OFF switch for the power sliding door system to be re-initialized to the OFF position.
- Manually open the power sliding door completely.
- Manually close and latch the power sliding door.
- Turn the power sliding door ON/OFF switch to the ON position.
- Open the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
- Close the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
9/9/2022 4:43:40 AM •
Chevrolet...
Answered
on Sep 09, 2022
Check engine light on says p2000 on code reader
The code is: P2000 NOx Trap Efficiency Below Threshold Bank1 and I do not know what that is unless it has something to do with the oxygen supply to the engine. Sorry I am not much help.
10/30/2015 6:24:22 PM •
Chevrolet...
Answered
on Oct 30, 2015
