20 Most Recent
Nikon ProStaff Laser 440 Rangefinder Questions & Answers
JUST GOT LASER 440 FOR CHRISTMAS AN CAMT GET IT TO COME ON AN WOR
As far as I know, you point it at something a distance away and press the power button. They're a very simple device but will likely not work indoors or over very short ranges.
If you're still having problems with it, it should still be under warranty, I would return it to the store immediately. If you have any issues with the store staff, do not leave the device with them and contact Nikon directly for help with warranty. You should never have issues with a product out of the box.
My 440 will not read
This is a common problem with this mode. If you are sure regarding the battery, then try to reset the rangefinder.You need to push the mode button and power button simultaneously for 30 seconds. This would reset the device.
If problem still persists, revert and we would follow up from there.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Measurement is off approx. 4' to 5'. Any way to
I didn't find the Prostaff laser 440 rangefinder on the website for Nikon.com, but I did find the 550 model. The specs follow:
Specifications
Measurement Range
11-550 yds
Increment Reading
0.5/1 yds
Magnification
6x
Angular Field of View (Real)
6°
Angular Field of View (Apparent)
34.9°
Viewfinder Display
meters/yards
Eye Relief
18mm
Diopter Adjustment
+/-4°
Power Source
1 CR2 Lithium Battery
Size (Length x Width x Height)
5.1 x 1.5 x 2.7 in
Weight w/o Batteries
6.3 oz
Objective Diameter
21mm
Exit Pupil
3.5mm
Supplied Accessories
CR2 lithium battery.
I did not read that there is a recalibration for the unit, although a consumer might expect that. Has it ever been dropped to your knowledge?
http://nikon.com/products/sportoptics/support/index.htm
The above link has contact information for service of the unit via telephone numbers.
Need the proper tool for a nikon prostaff range finder
Harbor Freight has a kit that has them in it and most industrial tool supply companies have them. It's a security screw. there are many kits availably with an assortment of bits in them. Drill Master has a 100 piece kit that's pretty cheap. Item#91310
