20 Most Recent Dacor ECD230 Epicure Electric Double Oven Questions & Answers
2answers
How to clean oven
We called a neighbor who has a similar oven. Thanks for you interest. Utne
1/15/2016 6:26:52 PM • Dacor ECD230... • Answered on Jan 15, 2016
Replace control panel or remove corrosion?
I would suggest a new control panel
11/17/2015 5:32:28 PM • Dacor ECD230... • Answered on Nov 17, 2015
Where is the internal fuse on a smeg range cooker
usually located on the backside
3/2/2015 8:25:50 AM • Dacor ECD230... • Answered on Mar 02, 2015
0answers
0answers
Dacor double oven, lower oven works fine, upper
I had the same problem after auto-cleaning my oven just before Thanksgiving. The cause was overheating...and the tripping of a heat sensor switch.
The switch (reset button) is located about 3 inches behind the door locking mechanism.
Removing the front panel (4 screws) that the door lock sticks through exposes the switch. Just push the little red button & your are back in business!!
9/23/2013 8:51:24 PM • Dacor ECD230... • Answered on Sep 23, 2013
2answers
My dacor cps130s shuts off
Barbara,
did you ever solve this problem? I am having the same one and cant find a solution. I have tried the reset button and it's still not working. any information would be helpful! Thank You!!
Katie
8/28/2011 9:25:47 PM • Dacor ECD230... • Answered on Aug 28, 2011
What does a beeping sound with F1 symbol mean?
Error F1 means that your Dacor Oven indicates element relay circuit failure. To resolve this issue the control board should be replaced as it has gone bad.
Good luck.
5/14/2011 12:20:40 AM • Dacor ECD230... • Answered on May 14, 2011
F4 error appears
F4
Open oven temperature sensor (RTD)
Check sensor harness and harness connection between
oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is
ok.
3/9/2011 2:59:26 PM • Dacor ECD230... • Answered on Mar 09, 2011
Dacor ECD230 Epicure Electric Double Oven Logo
96 questions posted
Top Dacor Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Ngoro
Are you a Dacor Oven Expert? Answer questions, earn points and help others
View Most Popular
Dacor Ovens
  • Dacor Ovens
Most Popular Question
replace control panel or remove
  • Ovens
