Resetting your leappad ultra isa breeze. First thing you need to do is to download and install Leapfrog connect. If it doesn`t download, there`s an offline download option available. After installing it, connect your leappad ultra with the usb cable to the pc. power it on. it should get connected. If it doesn`t maybe your anti virus software is blocking it. If this happens, go to your antivirus software settings and under firewall rules, select allow for leapfrog connect .exe. Then it should detect your leappad ultra. Go to left hand top corner , select My Products. Then select your leappad ultra. Then goto Settings on the right top corner and in the pop up, select Reset. It will take around 15 - 20 mins to reset it. All data will be erased. Hope it helpshttp://youtu.be/dnyle_-2aDYw
If you forgot the four digit parent lock code you set up for the LeapPad3, LeapPad Ultra or LeapPad Platinum, you may retrieve the code with these steps:
1. Using a computer or other device connected to the internet, go to www.leapfrog.com
2. Click "Log In/Register" (or "My Account" if already signed in) on the top right of the page.
3. Sign in with the email address used to set up the LeapPad.
4. You'll land on the "My Account" page.
5. Click "Account Information". Directly beneath the orange "Edit" button you will see the Parent Lock code information for any LeapPad3 or LeapPad Ultra set up using this account.
Forgot Parent Lock code on LeapPad
Go to settings and turn wifi on from your leapPad, then search for available networks till you find your home wifi, then enter the password and your connected!
Download and install Leapfrog connect. After installing it, connect your leappad ultra with the usb cable to the pc. power it on. it should get connected. If it doesn't maybe your anti virus software is blocking it. If this happens, go to your antivirus software settings and under firewall rules, select allow for leapfrog connect .exe. Then it should detect your leappad ultra. Go to left hand top corner , select My Products. Then select your leappad ultra. Then goto Settings on the right top corner and in the pop up, select Reset. It will take around 15 - 20 mins to reset it. All data will be erased.
IF you forgot the wifi password, there is a reset button on the router that you can use to reset it back to the settings that it came with. If you use that you will have to reset a new password.
Try pressing the on/off button to turn it off. I had a same problem. I depressed the on/off button for ~6 second or so and the device turned off. When I turned on again, the LeapReader no longer had a white light and was recognized by my computer.
Enter 1111 and it will say oops wrong password then enter 419 backspace and get rid of the 9 and then 27 worked like a charm took forever to find one that worked and this one worked for me once in change the 4 digit code to something ez
my leap pad ultra is at that part of turning off wher their is only a dot of wite left on the screen.it is still doing that and it has been at least 2 hours since i played it. it wont turn on either now.i am a kid sorry if their are spelling errors
