20 Most Recent
Bissell PowerSteamer Deep Cleaner Plum Upright Vacuum Questions & Answers
Will not spray water
When this happens you usually have a blockage in the tubing. Old cleaning solution gets dried up and hardens and then blocks the tubes. You need to take the tubing off and clean it all out or untill you find the blockage. Once you get it spraying agin clean the system with hot water and flush it all out. Always spray just water for a while after you use any cleaning solutions and this will keep the tubing cleaned out. Does this help? do you need more assistance let me know.
11/19/2010 7:11:16 AM •
Bissell...
Answered
on Nov 19, 2010
My Bissell little green machine has no suction at the hose end.
If your Bissell Little Green Machine has no suction at the hose end but good suction underneath the dirty water tank, try these steps: check for clogs in the hose and attachment, ensure the tank and filters are properly seated, test without an attachment, inspect for damaged hoses or seals, clean the machine, and run hot water through the hose. If the issue persists, contact Bissell customer support for assistance or consult your user manual for specific troubleshooting steps.
Bissell pro 2x healthy home carpet shampooer wheel not spinning
Hello Jeanette The answer from 'Rushikesh' that you thanked is from an Indian Artificial Intelligence Answer Bot. The site has been plagued with them for a month or so. They all answer in the same format 1. Repeat the Question. 2. Give five GUESSES to fix. 3. Tell you to consult a professional! From a real person : You need to change the drive belt, simple as that! If you turn the machine over an turn it on, if you carefully put your hand of the brushes, you will find you can stop thee brush from spinning. That shouldn't happen. ..
