20 Most Recent
Uniden G455 Guardian Wireless Video Surveillance System with 4.3" Touch Screen, G-455 Questions & Answers
Where are the free manuals
Here is the link where you can locate the owner's manual: https://www.uniden.com/product-information/owners-manuals
How to reset Uniden GMR1938-2
Monitor Mode Feature
Your GMR1038 radio allows you to listen for weak signals on the current channel at the press of a key.
To turn ON the Monitor Mode:
• For brief listening, press mon button. The icon blinks.
• Press and hold mon button for 2 seconds until two beeps sound for continuous listening. The receiver circuit stays open, letting both the noise and weak signals to be heard.
To turn OFF Monitor Mode:
Press mon button to return to "Normal" mode, and the RX icon stops blinking and disappears.
How to reset uniden GMR1938-2 radio
To reset the Uniden GMR1938-2 radio and turn off monitor mode, you can follow these steps:
1. Turn off the radio by pressing and holding the Power/Menu button until the unit powers down.
2. Once the radio is turned off, press and hold the Menu button.
3. While holding the Menu button, turn on the radio by pressing the Power/Menu button. Keep holding the Menu button until the display shows the Reset prompt.
4. Use the Channel Up or Channel Down button to navigate to the Reset option.
5. Press the Menu button to select the Reset option.
6. The display will show a confirmation message asking if you want to reset the radio. Use the Channel Up or Channel Down button to select "Yes" and press the Menu button to confirm.
7. The radio will reset to its factory default settings, including turning off the monitor mode.
After performing the reset, the monitor mode should be turned off on your Uniden GMR1938-2 radio. You can now use the radio normally without the monitor function active.
Uniden Pro340xl CB has no external power plug in port on the side although manual shows it should. Any idea why it's missing the side plug in ports?
One possibility is that the design of the radio has been updated since the manual was published, and the newer version of the radio no longer includes the side power port. In this case, you may need to refer to a more recent version of the manual to get accurate information about the radio's features and specifications.
Another possibility is that your particular radio may be a different model or version than the one depicted in the manual, even though it appears to be the same on the surface. It's possible that this version of the radio does not include the side power port for some reason.
If you are still unsure why your radio does not have the side power port, you could try contacting the manufacturer's customer support team to see if they can provide more information. They may be able to clarify any discrepancies between the manual and your specific radio, or provide guidance on how to power the radio without the missing port.
MY UNIDEN 4 CAMERA HOME SECURITY CAMERS MONITOR HAS LOCKED ME OUT AS I CANT RECALL MY PASSWORD
If you have forgotten your password for your Uniden 4 camera home security system and are unable to access the system, there are a few steps you can try to reset the password:
- Check the user manual for your specific system model to see if it provides instructions for resetting the password. Some Uniden security systems may have a reset button or a specific reset procedure outlined in the manual.
- Contact Uniden customer support for assistance. They may be able to provide you with a default password or walk you through the process of resetting the password.
- If the above steps do not work, it may be necessary to perform a factory reset on the system. This will erase all settings, including the password, and restore the system to its default configuration. To perform a factory reset, you may need to locate the reset button on the system or follow a specific reset procedure outlined in the user manual.
It is important to note that performing a factory reset will erase all settings and may require you to set up the system again from scratch. It is recommended to carefully consider this option and, if possible, try the other steps first.
