20 Most Recent Singer Inspiration 4206 Questions & Answers
Selector dial stitches doesn't work
Suggest you ask the seller of yr machine. It runs on computers... They can malfunction. Singers were the Best for decades. From treadle days into the '70's. When a repair guy told me Singer only made parts for 2 yrs post purchase. I have both of my Grandmother's treadle machines, and their scissors. Would Not buy a Singer, now.
2/5/2018 8:43:47 AM • Singer... • Answered on Feb 05, 2018
2answers
My bobbin isn't sewing correctly
If the bobbin stitches look out of whack, your machine is probably threaded incorrectly. rethread with the presser foot up and see if this fixes the problem.
8/19/2016 2:58:03 AM • Singer... • Answered on Aug 19, 2016
The automatic threader isn't working. the bobbin isn't sewing correctly?
make sure the bobbin is turned counter clock wise, also try changing the bobbin, also try a new needle. you may have to have the automatic needle threader checked to see why it's not working
5/26/2016 3:52:15 PM • Singer... • Answered on May 26, 2016
My automatic needle threader ins't working and my bobbin isn't threaded correctly. What should I do?
You can always thread your needle manually. Sewists have done it for over 100 years. First, lick your index finger and then swipe it across the back of the needle's eye. The moisture helps draw the thread through the eye. Here's a free manual for your machine: https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwim14rG0OfMAhUq34MKHcliAiAQFggpMAI&url=http%3A%2F%2Fwww.singerco.com%2Fuploads%2Fdownload%2F499_4206_4212.pdf&usg=AFQjCNE6O1_RDshpzK_IEMz7gF8VchgIqA&cad=rja Here's a video showing how to thread it: How to Thread Sewing Machine Singer Inspiration ...
5/20/2016 2:46:00 AM • Singer... • Answered on May 20, 2016
Motor is running but the needle is not going up and down
Did you remember to re lock the cam if you recently wound a bobbin?
3/8/2015 4:31:08 AM • Singer... • Answered on Mar 08, 2015
Hook timing ajustment on singer tradition
When the needle is going up, the hook point comes around and almost touches the needle at the back just above the eye, there is usually an indent in the needle just above the eye for the hook tip. the clearance is usually "almost touching by a hair" The tip of the hook should be just coming out from behind the needle and the bottom of the point should still be at least a "hair" above the top of the eye... If that is not clear see image.f68312ec-ddb6-4007-b635-61d2971f650a.jpg
7/24/2014 5:05:06 PM • Singer... • Answered on Jul 24, 2014
2answers
How to snap back the bobbin case for a inspirational singer 4206
I'm sorry, but I'm not sure what you want to do with your bobbin case. If you want to put it back or take it out, you must unscrew the two screws that hold the needle plate, remove it, and slip the bobbin case in. Make sure that you put the bobbin case in correctly. It is on page 64 of your User's Manual; if you cannot find your manual, you can download it for free from here. http://www.singerco.com/uploads/download/499_4206_4212.pdf
7/4/2014 6:03:02 PM • Singer... • Answered on Jul 04, 2014
Ruffler foot bobbin tangles
I suspect that the bobbin thread you are talking about is in fact the top thread that has been pulled under the material, make sure that the top thread is pulled into the tention discs firmly and that there is no fuzz in with the thread, also make sure the top thread is properly threaded and is actually in the take up bar .
4/13/2014 7:02:21 AM • Singer... • Answered on Apr 13, 2014
Sewing through screen printing t-shirts
Try using wax paper.
3/21/2014 2:24:21 PM • Singer... • Answered on Mar 21, 2014
Needle is not moving
Of course I have to guess here--not seeing the machine, but it appears that your motor is working fine. That would leave two possibilities, I think. The first is a defective foot pedal. The second is, when you push the bobbin winder, it engages a clutch that diverts power from the needle shaft to the winder. It is possible that the clutch is stuck. To find out, disengage the bobbin winder and press the foot pedal, and see if the bobbin winder spindle is still spinning.
1/18/2014 6:40:23 PM • Singer... • Answered on Jan 18, 2014
0answers
Machine only swings but doesn't stitch ("walk")
Please check the needle position.
11/21/2013 9:51:59 AM • Singer... • Answered on Nov 21, 2013
manual
All of a sudden my Singer Inspiration 4206 stopped working. When I press the foot peddle it only makes a swinging sound like when you're only swing a motorcycle but not driving it. If I turn the hand
If the swinging sound is from the motor, right side just below your hand wheel, possibility your motor belting is loose or broken. If you don't have mechanical skill / experience, suggest to get your local technician to fix it.
11/11/2013 12:53:19 PM • Singer... • Answered on Nov 11, 2013
Bobbin case came out of the machine. how do I
here is a link for a free manual,, it should show how to put the bobbin case in the machinehttp://www.singerco.com/uploads/download/499_4206_4212.pdf
9/4/2013 5:29:23 PM • Singer... • Answered on Sep 04, 2013
Machine constantly runs when you turn on the power switch
it sounds like there is a short in the wiring somewhere. it would bea good idea to have the machine serviced.
2/12/2013 5:51:47 PM • Singer... • Answered on Feb 12, 2013
2answers
The foot pedal on my
Hi lawoffice474...
Unplug your foot pad from the machine and the electrical receptical.
Try moving the foot pedal with your hands, back and forth as if you were pressing your foot on it.
Did it loosen up?
If yes then you still need some maintenance...
If no then you still need some maintenance.
Disassemble the foot pedal and take as many pictures as you need to be able to reassemble it.
Once you have disassembled then you will look to oil (one drop max) the pivot points of the foot pedal, like the hinge assembly, reostat linkage,etc.
Once you have it oiled then try moving the foot pedal again my hand before reassembly.
If everything moves ok then your good to go...
Reassemble the foot control.
If not then its time to replace it with another foot pedal such as one of these at this webpage below:
Please take time to rate me thumbs up.
http://www.sewingmachinesplus.com/singer-foot-controls.php
10/10/2012 11:02:56 AM • Singer... • Answered on Oct 10, 2012
Singer Inspiration 4206 Logo
40 questions posted
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Singer Sewing Machines
Most Popular Question
bobbin case came out machine
  • Sewing Machines
