20 Most Recent
Frigidaire 17.8 cu. ft. / 504 liter Commercial Freezer FFC18K1CW Questions & Answers
I got a commercial frontload coin op washer for
The problem was never solved. I never got to chat with anyone about anything at all, and I dont have a ******* freezer. If I was able to chat with someone I would have been able to get the proper model number from my washing machine.
Cancel my subscription and I want a refund in full. Dont send me any more emails, unless it confirms my subscription is canceled. I will not use your service. Your website is to complicated and is designed to rip people off.
The timer had gotten stuck and everything thawed.
Did you replace the timer? If it got stuck once it will get stuck again. If you did replace the timer, are you sure you connected the wires to the correct terminals? If not you will be in defrost for 12 hr, and cooling for 20 min. (example) Hope this helps
Frigidaire side by side: water fills up in bottom of freezer
You have a blockage in your drain tube, at the bottom of the metal tray there is a hole which is connected to a tube which runs down the back of your refridge to a pan next to the compressor. It is an easy fix have done this 1000's times. Remove back panel in freezer, grab a heat gun or hair dryer and melt the ice it the bottom of tray. Clean the water in the tray with some paper towel next get some hot water in a measuring jug and pour into the pan(hot water will help melt ice in tube) repeat this process a couple of times and then get a curtain wire or something flexible to push down the pipe to clean the blockage...you will know when the blockage is clear because the water in the pan will suddenly drain off....put cover back on...make sure to unplug appliance before servicing...hope this helps :)
My Frigidaire up right freezer is showing an error code "FF" and is beeping. What is the issue?
Hey friend, thanks for your inquiry!
Within your Frigidaire freezer the error code "FF" stands for freezer failure. I would perform a reset on your appliance which can be done by either unplugging the power cord or flipping the household circuit breaker. Once the freezer has come back on you should be able to push the "Down" button three times to start it back up.
If that does not correct the issue Please respond back I would like to assist you with any additional information. Hope this helps to some degree. -Matt
