20 Most Recent Hamilton Beach Water Cooler with Storage Cabinet Questions & Answers
Hamilton Beach Water Cooler Bottom Loading BL-5-2 is no longer self sanitizing.
Question edited for clarity. Question moved from Cars and Trucks category. The indicator light may have failed. No data exists on your issue. https://www.google.com/search?q=Hamilton+Beach+BL-5-2+not+self+sanitising ..
8/6/2023 5:09:40 PM • Hamilton Beach... • Answered on Aug 06, 2023
Looking to buy the spill resistant piercing valve
My cooler is leaking, and I believe is missing the spill resistant piercing valve. Where can I purchase a valve.
1/31/2022 11:11:57 AM • Hamilton Beach... • Answered on Jan 31, 2022
2answers
Cold water never quits trying to cool water. runs
Hello, this is going to be a bad thermostat. This is located behind the grill in the back. It has 2 electrical wires and a metal wire that goes to the tank, you should replace it. Hope this helps! Mike
11/13/2021 12:24:45 PM • Hamilton Beach... • Answered on Nov 13, 2021
5answers
How to clean/repair water cooler
I have a hamilton beach water cooler with storage cabinet # 87330. The cold water is not cold and the cooling light stays on. What is the problem and how can I fix it? Thanks!
8/19/2016 1:04:49 AM • Hamilton Beach... • Answered on Aug 19, 2016
3answers
How can I repair it if the cooler will no longer cool?
I am looking to purchase this 87307. Do you still have it? My e-mail is [email protected]
2/1/2016 1:54:37 AM • Hamilton Beach... • Answered on Feb 01, 2016
2answers
My water cooler won't cool
Check to see if fans are working i just bought a used one and one of the fans was not working and i fixed it and sems to be working
2/1/2016 1:46:07 AM • Hamilton Beach... • Answered on Feb 01, 2016
Water is coming out of
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
8/17/2015 1:47:21 PM • Hamilton Beach... • Answered on Aug 17, 2015
2answers
Frig not cooling
The thermostat has become defective or it has lost freon or the compressor has failed.
Unless it is the thermostat, It may not be cost effective to repair so check the cost of a replacement.
1/8/2015 1:43:14 PM • Hamilton Beach... • Answered on Jan 08, 2015
Can you put treated tap water in a water cooler?
HI.UMMM WELL i would think is not a problem but normally tap water has fluoride and clorine which gives a bitter tate and cloudy water.sooooou. u make your mind up...plus the ready bottle is sealed as well as one way ticket in and out.good luck hope this helps ali
10/20/2014 6:12:53 AM • Hamilton Beach... • Answered on Oct 20, 2014
Can you put coolant back in motor
If by coolant you mean freon, and if by motor you mean compressor, then no, you can not do it without special equipment. It requires a technician. Usually cheaper to replace the water cooler.
8/13/2014 5:10:21 PM • Hamilton Beach... • Answered on Aug 13, 2014
How to clean and sanitize a Kentwood water cooler?
Using one cup of bleach Per 5 gallon jug. Find the drain plugs on the bottom of the unit there are two. Drain unit of any water that is in it now. Replaced drain plugs. Place 5 gallon jug on top of unit and allow unit to fill. Be sure that heated water is off. Open spigots and allow a gallon of water to drain. After about 15 minutes open the drain plugs and allow all of the solution to drain out. Proceed to fill the 5 gallon jug with clean Clear filtered water and allow that to drain thru the unit, do this five more times.
10/29/2013 4:46:38 PM • Hamilton Beach... • Answered on Oct 29, 2013
2answers
Water Dispenser hamilton Beach Water Cooler
my water cooler worked yesterday,today I get nothing from either the hot or cold water? Is this a simple fix or di I start with a new one?
8/6/2013 5:55:49 PM • Hamilton Beach... • Answered on Aug 06, 2013
Hamilton Beach Water Cooler Model 2202 cold water
No Cold Water
Hi. I have a Hamilton Beach Model 2202 and it's been working fine until last week. Now I have no cold water.
1/13/2013 1:20:23 AM • Hamilton Beach... • Answered on Jan 13, 2013
3answers
Hamilton beach model 87307 water
Check the fans
8/11/2012 7:48:21 AM • Hamilton Beach... • Answered on Aug 11, 2012
3answers
Cold Water not squirting out cold water
To resolve this problem, unplug the dispenser and let it sit for about 24 hours. I had this problem happen to me and I took the unit apart to find out the cause. I discovered that the the water cooling mechanism developed a big chunk of ice inside of it and it basically blocked the flow water. Allowing that ice to melt should resolve this problem. It did for us.
7/19/2012 6:19:11 PM • Hamilton Beach... • Answered on Jul 19, 2012
My Hamilton Beach water cooler is just dripping water on the cold side but running free on the Hot side.Yesterday I flushed the cooler out with vinigar and hot water but today we have a problem
I have same problem keeps running till freeze up so i put a timer on the power cord it shuts off at 11.00 pm till 6am in morning the water keeps pretty cold and a lot cheaper then a new board or scrapping the cooler after starting for about an hour water is cold
7/6/2012 2:05:06 AM • Hamilton Beach... • Answered on Jul 06, 2012
My water dispense model 87330 by hamilton beach
Sounds like the thermostat is your problem. That would be the only thing that will allow the unit to continually run.
11/9/2011 10:20:08 PM • Hamilton Beach... • Answered on Nov 09, 2011
Cold water is not coming out cold
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/27/2011 8:00:37 PM • Hamilton Beach... • Answered on Sep 27, 2011
Cooling compartment not cooling
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
If you still have trouble GO HERE:
I'm
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/15/2011 3:23:14 PM • Hamilton Beach... • Answered on Aug 15, 2011
Hamilton Beach Water Cooler with Storage Cabinet Logo
247 questions posted
Top Hamilton Beach Water Filters & Coolers Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Hamilton Beach Water Filter and Cooler Expert? Answer questions, earn points and help others
View Most Popular
  • Hamilton Beach Water Filters & Coolers
Most Popular Question
looking buy spill resistant piercing
  • Water Filters & Coolers
