20 Most Recent Dometic RM2193 Compact Refrigerator With Ice Box Questions & Answers
2answers
Can I transport a whirpool side by side
The short answer is yes, but the key is to make certain not to plug in and start the fridge for at least 24 hours once it is upright and in the final location.
The reasons manufacturers caution against transporting/moving a fridge on it's side also has to do with the possibility of damaging the doors and hinge plates. The big reason is because people tend to want to start filling up their new fridge with food right away, so they plug it in once it's in their house.
If a fridge has been shipped on its' side, the compressor oil tends to wick/flow into the piping and can cause a failure, if not allowed to drain back into the compressor when the fridge is placed back upright.
Although not the best way to transport, you can do it if you allow time for things to settle back before powering it up.
6/24/2023 10:17:43 PM • Dometic RM2193... • Answered on Jun 24, 2023
I use a Dometic RM2193 in my pop-up camper. Can
Usually from the Bottom of the refrigerator you should have minimum of 43f or colder than ambient. Should work very close to same on both gas and 110, on Dc it may not cool as good. From your description you may have an issue with ventilation. Cold air needs to flow in through the lower vent and out through the upper, if it cant, cooling efficiency is lost. Adding a fan kit can help on hot days. On gas you may have particles that fell down in the burner. Just take the cover off, take the burner screw out and blow down into burner to clean out. compressor or canned air works fine. If cleaning the burner doesn't improve it enough on gas to match electric you have to make sure your regulator on your rv has enough pressure... the fridges require 11 inches of water column.
5/5/2017 9:57:55 PM • Dometic RM2193... • Answered on May 05, 2017
0answers
0answers
How do I set switches to run on 12 vdc while on the road?
It will take some diagnostics to find the answer so I am placing a link to a diagnostics manual=> Dometic RM2193 Diagnostics Manual You either have a defective 12V heating element, blown fuse or a defective switch. I am here should you have questions, Thanks John T. Appliance 911
6/29/2015 9:24:37 PM • Dometic RM2193... • Answered on Jun 29, 2015
Dometic RM2193 Compact Refrigerator With Ice Box Logo
Popular Tags
74 questions posted
Top Dometic Refrigerators Experts
Jay Finke
Jay Finke
Virgil Watts
Mike Cairns
Mike Cairns
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Dometic Refrigerators
Most Popular Question
transport whirpool side side
  • Refrigerators
